Question about Coleman Powermate Powermate 5000W Generator
Where can i find oil dip stick for a generator coleman powermate subaru engine.
  • 68 Answers
On the side of the engine there is a bolt like piece with two round like nodules on it, its plastic.
Posted on Oct 08, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
When checking the oil on the motor should the dip stick be screwed in for the correct oil level or just setting in the hole??
For Honda engine, just set in opening (unless it has a push-in dipstick like on auto ),
Briggs, most models, and other brands best to thread in unless stated in manual.
If oil cap is very close to base of engine and does not have an oil level marker, then fill to top thread (many older engines that did not have oil senser).
Dec 16, 2010 | Coleman Powermate Powermate 5000W...
I would like to know what type and how much oil do I use in my powermate generator with the Subaru 10hp engine. thanks you
Your small engines require ordinary 10W30 motor oil.
Don't turn machine on its side or upside down to drain oil, or oil will run into carburetor.
Use a plastic hose to remove old oil
Oct 22, 2010 | Coleman Powermate Premium Plus 6250W...
How much oil will a husky generator use?
When I change mine I believe it takes just under a quart....
once you get half the bottle or so in your need to start checking the dip stick...
heatman101
Aug 31, 2010 | Coleman Powermate Subaru 5000W Portable...
Hello, I have a Coleman Powermate 5000/6250W and I can not fing the oil drain plug. There is one oil dip stick on each side of motor. Starting to feel like a dip stick myself.
I worked at a tool rental while attending college and have felt the same way as you when looking for oil drain plug on various tools. Some engines do not have a plug and you must tilt the engine to get the oil out. Others had a plug but could remove it so had to tilt anyway. Most small engines had the plug along the edge of the base of the engine. Look where the engine mounts to the frame of the generator. The engine block is about 1/2 to 3/4 of an inch thick there and usually has a 1/2 " square head plug. The oil drains very slow thru that hole. Some gen sets had a small tube (4 - 5 inch ) attached to drain hole that made it easier to catch oil. Good luck.
Jul 07, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate PM0435001 5000W with a Subaru EX30D 10HP OHV/OHC gasoline engine. I want to change the oil and cant find a drain plug. Did I overlook it or does it not have a drain plug? If not...
You probably overlooked the drain plug, it is usually located on the mounting base of the engine. BUT, there have been some engines (old cheap ones) that the oil was drained by tipping the engine and draining out the oil fill. I am almost positive yours is not one of these.
Your manual is here, but that is only an "insert". It does look like the drain plug is located on the base of the engine. Find the spark plug, and the drain plug is almost directly underneath it at the very bottom of the engine.
More information is available from Subaru's website, including owners manual and especially a service and parts manuals. Your drain plug is item #13 on page 2 of the owners manual located here:
http://www.robinamerica.com/pmanuals.aspx?pid=80
Jun 06, 2010 | Coleman Powermate Powermate 5000W...
Where is the oil drain plug for a briggs and stratton 11 hp engine?
ACCORDING TO POWERMATE, THIS GENERATOR IS EQUIPPED WITH A 10HP SUBARU ENGINE. WHAT MODEL IS YOURS? AND R U SURE IT'S A B&G ENGINE?
Dec 14, 2009 | Coleman Powermate Powermate 5000W...
Won't start
low oil switch stuck. most new small engine have a low oil swich in the oil pan. this can be by passed or replaced.
Dec 21, 2008 | Coleman Powermate Subaru 5000W Portable...
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
207 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
