Question about Brother MFC-9840CDW Laser Printer
When I print I have black dots on it and a red
When I print I have black dots on the page and a red line on the edge of the paper
  • adolfsingh Oct 08, 2009
    The document prints normally, but along with it a red line prints on the right hand side (edge) as if someone took a thin red marker and ran over the edge of the paper.
    Also, about one inch from the right side there are several ink marks (black). These are evenly spaced and looks like some one put black marker pen dots.
    There is something happening with the black and red ink cartridges or the hardware that handles these two inks is causing it.
  • Mikecanfix May 11, 2010
    Does the text in the document print also? Is the red line on the side of the page, top or at the bottom?
  • 37 Answers
The drum probably needs to be cleaned. Refer to the Routine Maintenance section in Appendix C of your Users Guide.
Posted on Oct 09, 2009
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Printing thin black lines the length of my color pages, HP laserjet 3800
one question......
do the lines go off the edge of the paper?
if so either the black drum unit or the belt has gone bad.
if the lines stop before the edge of the paper it could be on the print job itself.
go through the menu and look for demo pages or the configuration pages to print and examine them.
Jan 11, 2011 | HP LaserJet 3800 Printer
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
Prints black dots at bottom of page - photoconductor was replaced earlier today
The black dots could be a few things, the most likely would have something to do with the drum area because the dots didn't appear until after service. If the dots are only about an inch apart it is probably the charge roller. If there is only 1-2 dots per page, the issue is likely with the drum. These figures are assuming you are running 8 1/2 x 11 paper with the long edge being fed in first. If this is the case, you can change the paper to feed with the short edge first and this may get you by until the technician gets back out to fix it.
Nov 18, 2009 | Ricoh Aficio 450 Copier
When printing the sheet of paper has 3 dots on the
Yes this could be the drum.
You could remove the drum and carefully look for the pattern of dots etc that you are getting on the page but on the drum surface.
I would suggest replacing the drum 1st and retrying.
If the black lines are just down one edge then the fuser could be to blame for the black marks but without being able to see the page i cant tell. The drum is certainly my 1st suspect and is easy for you to try.
If you are in Berkshire try www.repairmyprinter.co.uk for additional help
Aug 24, 2009 | HP LaserJet 2840 All-In-One Printer
Printer prints a colour dot at every pages edges
Hi ,
if u get red dots on print it may be problem with Red cartridge Lick age please check u r printer with Ok cartridge .if same problem with new cartridge then u need to clean Mirror built in lance assembly
Jul 11, 2008 | HP LaserJet 3800dn Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Landscape print gives dots or lines in the upper margin
unplog your printer.clean your printhead of the printer by a tissue paper.
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Brother MFC-9840CDW Laser Printer Logo
604 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
