Question about Sharp AR-M205 Copier
AFTER changing the drum the unit is putting toner shade on the page like it is over exposed. sShows up mostly when if run through the document feeder
  • Sharp Master
  • 1,297 Answers
Change the toner antisplit blade (located under OPC drum cleaning blade) and perfor the auto toner density control process.
Posted on Oct 08, 2009
Have a Brother MFC7440N fax - copy machine, replaced toner, copies are all coming out gray with horizontal lines
Uh oh. Do the prints come out the same way and the faxes? If you're lucky, it's something on the document feeder or glass. If you're not so lucky, guess what the paper passes over? Likely you may have put something in the document feeder that scored the drum. However, before you get all nervous, look at page 119 of your manual. There are instructions on cleaning the scanner glass, the ADF window, the corona wire, and the drum unit. It's a messy job :-)
Here's a manual if you can't find yours http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7340_7345N_7440N_7840W_EN_2382.PDF
Carl
Jun 25, 2011 | Office Equipment & Supplies
BROTHER-MFC7430 Toner life end
actually, you dont' really need to replace your drum, your drum actually is good for 5-6 years.
you just need to clean up the drum with duster and put that back into the machine.
when reset the drum, you just need to open the front cover and press Clear buttom then 1.
after that the whole thing will be reset and ready to go for it.
Dec 27, 2010 | Brother MFC-7340 All-In-One Laser Printer
Line is on paper once printed
A dark line on printed pages that are printed directly from the computer are most likely coming from the Drum Unit.
A dark line seen after making a COPY of a document using the feeder on top, is caused by a dirty scanner glass.
In the first example the fix is to replace the drum unit.
In the 2nd example you need to clean the scanner glass. The glass can be seen by lifting up the automatic feeder on top of the machine and exposing the large original glass. The document feeder glass is the smaller thin strip of glass that is located just to the left of the large glass. Clean this strip well with a cloth/paper towel and a bit of glass cleaner.
Good Luck and Thbak You for using Fixya.
WheatlandServices
Oct 12, 2010 | Brother MFC-8460N All-In-One Printer
I'm getting drum error message, it says move blue tab back and forth, I don't what the drum is and I don't see blue tabs
Open your document feeder cover (it pivots away from you), then open the forward top cover (it pivots towards you). Inside the machine is the drum / toner unit, remove it. On top of this assembly is the blue tab (plastic handle) either on the left or right side. Slide that tab back and forth ~ 4 or 5 times. Reinstall the drum / toner unit. Close the top cover, then the document feeder cover. Done...
Dec 18, 2009 | Brother IntelliFax-2820 Laser Fax
Dirty prints
You have not stated if it is a laser or inkjet.
On laser machines this can usually be one/both of.
1 Faulty toner / poor quality refill (sometimes happens as toner runs low. (Replace toner)
2 Wear in the drum unit (Replace Drum unit)
Jul 01, 2009 | Brother Office Equipment & Supplies
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
Replaced drum fax 2820
Hi, #'s 6, 7 and 8 below explain how to reset the drum indicator.
Hope that helps...
Lbcoaster
How do I replace the drum unit?
Description:
Follow the procedure below to replace drum unit.
CautionDo NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray1.gif Caution
    Just after you have used the machine, some internal parts of the machine are extremely HOT! Never touch the shaded parts shown in the illustration.
  1. Open the front cover and pull out the drum unit and toner cartridge assembly.
Caution
    To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  1. Hold down the lock lever on the left and pull the toner cartridge out of the drum unit.
Note
    • Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
    • Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag.
  1. Unpack the new drum unit.
  1. Reinstall the toner cartridge into the new drum unit. If you put it in properly, the lock lever will lift automatically.
all-ug-16.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Install the drum unit and toner cartridge assembly in the machine.
  1. Press Options.
  1. To confirm you are installing a new drum, press 1.
  1. When the LCD shows Accepted, close the front cover.
Related Models FAX-2820, FAX-2910, FAX-2920, MFC-7220, MFC-7225N
Aug 02, 2008 | Brother IntelliFax-2820 Laser Fax
Printing problems
There could be a couple reasons. One, it may be the person sending you the fax that has a problem with their machine. The easiest way to find out is, put a clean document in the feeder and make a copy. If the copy is clean then you know it is not a problem with your machine. The other possibility is that when Brother sells these new machines they only provide you with a starter drum and toner. Many times the drum may have defects and the machine does not detect these so you will not get a message telling you to replace it. If you do determine its your machine I would start by replaceing the drum unit first, then the toner.
Good luck
John
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Sharp AR-M205 Copier Logo
63 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
