Question about Dynasty Grilling
H Burner replacement
Hello, Having lots of trouble finding new burners for a Dynasty 30 inch freestanding grill. The cast burners that came with the unit are rusted through both of them. It seems to me that if you spend the kind of money on a grill such as this you would expect at the least stainless steel burners. Looking for new stainless burners for this unit the venturis are in good shape. Model # is DBQ30FN.
Thks. Bob.
  • Mike Hollander
    Mike Hollander Aug 02, 2017
    There are aftermarket cast iron burners available for approx $64.95. Otherwise, the OEM burner is a Dynachrome which is a chrome plated cast iron that is almost $300. I do not believe that the cast stainless is still available.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Posted on Aug 02, 2017
4 Suggested Answers
  • 9 Answers
SOURCE: I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Posted on Jun 26, 2009
  • 9 Answers
SOURCE: I have a ducane stainless steel ducane 30400042.
DeBruce
  • 145 Answers
SOURCE: why is my stainless steel ducane grill rusting out
There are two basic types of stainless steel; -highly corrosion resistant/nickel-chromium steels and less corosion resitant ferritic and martensitic steels. Basicly the less nickel in the mix lowers the price to the consumer and makes great products cost effective to the consumer. You need to "pacify" the surface to mitigate the condition.
Use DeBruce Polish to remove the rust and "pacify" the surface. This is a great product is ECO-FRIENDLY just another reason we like and use professionally. You can find DeBruce Polish at debrucepolish.com.
Posted on Jul 27, 2009
Grill burner will not burn like the other
Dynasty burners are replaceable and they are very good appliances (when they're actual dynasty, manufactured by jade).
About 90% of the time someone complains about burner flames or heat it is the check valve needing to be reset. I explained this earlier but let me know if you need to know how to do this.
On the rare occasion the check valve is not the problem (and 90% could actually be very low because this is almost always the problem!) the burner could need to be cleaned or replaced or the gas orifice and valve could need to be cleaned or replaced.
Dynasty burners are very heavy cast iron, single venturi "H" burners. Although coated cast iron is quick to oxidize and sometimes because of the coating the rust will start from the inside out. Lift the burner from the back of the barbecue and slide it away from you. Check to see if it is corroding from within.
The single venturi tube extends from the bottom of the burner into the control panel where it slides over the gas orifice at the tip of the control valve. It is possible for the gas valve to get a small insect crawl in through the orifice and build a nest inside the small cavity inside the control valve.
Remove the burner to reach through the inner firewall with a ratchet to pull the orifice and then check the inside of the orifice and the inside of the valve behind the orifice. If something is clogging the orifice the gas will flow unevenly and you may have flame-flashing inside the control panel which will destroy the lubrication in the control valves and will destroy the ignition parts inside the control panel.
I suggest the check valve solution with the drip tray removed so you can look from under the control panel for gas leaking through the air holes in the venturi tubes. Also, remove the control panel and leak-test the valve with soapy water because if previous flashing occurred the first casualty is usually the seal between the valve and the gasket which can lead to more leaking gas.
Check valve:
Turn everything off (tank and bbq).
Disconnect hose and regulator from LP tank.
With tank disconnected, turn the BBQ on. Turn every valve to "high" and leave it for 5 minutes.
Turn everything off -- completely off.
Reconnect tank but turn the tank on very, very slow. The check valve problem occurs when gas "hits" a swing arm too hard as the gas leaves the cylinder so turn the cylinder on very slow and then relight the grill.
Jan 25, 2014 | Dynasty DBQ-30 (LP) Grill
I am having trouble finding a burner for my Patio Classic Gas Grill Model : NX400! Can you please help me find one?
Unfortunately, your model Patio Classics Grill has been discontinued by the manufacturer. However, many manufacturers use the same type burner and those can be used on your grill. All you have to do, is compare your old burner (shape, size & length) to one of theirs. I have included a link to an online grill parts store that stocks hundreds of burners. I am sure you will be able to find one that matches yours there.
http://www.grillstuff.com/gas-grill-burners/?cat=48
Good luck & Happy Grilling!
Mar 28, 2011 | Patio Classic NZ-400-S Grill
I have a Viking Grill model VGBQ530 with cast iron burners that need replacement. I cannot find the exact model no. with these replacement burners however it appears that Viking now have a replacement made...
That is correct. Viking no longer supports the Cast Iron Burners. There is an aftermarket Burner VIKU1 that comes with mounting brackets to convert older Viking Grills that used a Cast Iron Burner to be able to switch to the stainless steel burner. The large bracket attaches to the center tube and has two screw holes and screws for mounting to the rear of the housing. The two smaller brackets mount to the two holes at the rear wall of the housing and create a ledge for the end of the two tubes to rest on.
Jun 11, 2017 | Viking Grilling
Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Oct 31, 2009 | Thermos 0210-1309 Turkey Fryer
Vermont casting ignitor dont work install new new button and batteries
igniter to burner gap on 4 burner jenn aire 480 (vermont casting built} gas grill
Apr 19, 2009 | Vermont American Tool Company VM600BSP...
Meridian 5 burner trouble
Yes you can fix it. Carefully remove the screws that hold the panel where the burner knobs are, There are 3 screws on each panel under the side shelf. There is another screw up underneath the face plate as well. Once the screws are out pull the face plate up and out so that all the tubes are disengaged. It should rest about 2 inches tilted back. Now remove the grates and burner covers and inspect the burner tubes. You will most likely find that spider webs or hornets have blocked off the gas flow to the burner. carefully clean every burner tube out and put everything back. You also may want to use a bit of sandpaper on the ignitor tip. Put everything back together and you should be good to go. It seems all Ducanes attract spiders on the burners...
Apr 06, 2009 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Need 3 burners for Dynasty gas grill model DBQ-42-F-L .
www.appliancefactoryparts.com
www.Grill-Parts.com
www.appliancefactoryparts.com/gasgrillparts/brands/dynasty/dynasty-other-parts.html
Feb 01, 2009 | Dynasty DBQ-30 (LP) Grill
Grilling Logo
286 people viewed this question
Top Dynasty Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Dynasty Grilling Expert? Answer questions, earn points and help others
