Question about Kenmore Dishwashers
Dish washer will run through all the cycles but the pump will not work and it is full of water
  • 3 Answers
Sounds like either the pump has gone out or is clogged. Sorry if I am restating the obvious, but if the pump has gone out then it will most likely need to be replaced. I would first of all make sure nothing is clogging the intake at the bottom of the dishwasher tub.
Posted on Oct 08, 2009
5 Suggested Answers
  • 12 Answers
SOURCE: will not pump out dirty water
Is it hooked to a garbage disp. If so make sure the knock out is out. Then if you can use a volt meter. take off the 2 screws at the bottom of the unit on the left side is your drain pump. take off the 2 wires put your meter on ac and put your leads on the wires then run it in a cxl cycle. (the cxl will depend on your unit you will press two buttons @ the same time and hold it it will light up 2(2min))
if you get 110 you have a bad pump........
Posted on Dec 23, 2007
SOURCE: dish washer that does not pump out the water on it"s final cycle
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Posted on Feb 20, 2009
SOURCE: The water does not circulate throughout the
have a Bosh SHU43C dishwasher. had used the cancel/drain and now can't get it to stop drainning. tryed everything can think of. what now
Posted on Oct 15, 2009
sodeep
  • 3267 Answers
SOURCE: the dish washer ran its full cycle but won't shut
The drain stuck cycle ( I presume you mean drain pump running constantly ) are directly related with overfill scenarios for Asko dishwashers of this era. This is meaning the control is indicating an overfill has been detected. Whether the unit has actually overfilled or not remains to be seen.
In the event it has, the outlet/drain pump motor is automatically turned on via either the pressure switch or a float in the base if sensing an overfill and removing water from inside the dishwasher will do nothing to resolve this error, but you can...
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base.
If the unit works fine after resetting the power/breaker it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump.
If not, there are a couple of other possibilities that I'd focus on.
**again insure power to the unit is off**
The first is the float and subsequently, float switch. If you've removed the service panel at the bottom, or toe plate, you need to locate the float and it's switch. It will be located directly behind where your main electrical junction is...
i.e.
Once you've located the float behind the main connection plate, you should see something like this image below,
i.e.
With the aid of a long screwdriver or if you can reach it, move the float up and down and listen closely for the switch to "click", indicating it is indeed functioning.
Restore power again, and see if this resolves the issue, if not try this next...
The pressure switch too can cause the drain/outlet pump to run constantly ( and usually all the lights to flash or "F2"...depending on the era and model of the Asko...ones with displays show F2 ).
As I was saying the pressure switch is the component which controls the normal fill level and the overfill detection...pre float activation. The float is primarily the last ditch safety to notify the user in the event of a overflow, back-flow, or leak underneath the unit to service or call for service to the unit.
It too is located under the machine and is mounted to the sump well assembly as shown, the large arrow indicates the switch while the small is the hose.
i.e.
The issue is possibly just the hose going to the switch is clogged with debris such as dirt, detergent buildup etc and will be remedied by blowing it out.
The best way to do this is to remove this hose at the switch in the location indicated above, be very careful as to not break the hose off with the part of the switch inside, they can be delicate.
I typically work it loose with a tiny screw driver gently working it away from the switch. Once removed, pour a small amount of hot water, white vinegar or "CLR" through the sump from within the tub...or you can try blowing it through with "lung power".
The other end of the hose is located at the back of the sump well and is quite vulnerable to blockages over time due to detergents, dirt, and such.
This is the location...do not break this or you will need to replace the entire sump well...no fun.
Large arrow is pointing back to pressure switch, small indicates connection to sump well, sorry for the poor quality...it's hard to get in there with a camera phone, ha ha !
i.e.
That's almost the extent of the possible causes of this error. Of course it could be the pressure switch has failed, the float switch has failed or ultimately the control has failed, but not likely.
Posted on Jan 21, 2011
Dish washer not emptying
put your model # into a google search and choose a place that has parts and look up your drain pump. you probably have either a clogged drain hose, not likely, or a bad pump.
May 13, 2012 | Dishwashers
I HAVE A BOSCH DISH WASHER SGS43A32GB/01 WHICH APEARS TO FLOOD NEAR THE END OF CYCLE
check base for leaks or holes. This is a very thin sheet of stainless steel that gets easily punched if some heave shart or pointed cutlery is falling onto it. also check proper operation of float switch underneath it.
Feb 01, 2012 | Dishwashers
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Nov 01, 2009 | Dishwashers
Dish washer that does not pump out the water on it"s final cycle
Dec 27, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Ge quiet power 3 troubleshooting
First clean the sprayer arm of all debris. In the back of most dishwashers there is a screen on the bottom that is often full of junk, debris and other stuff from dishes not being scraped off.
Clean that screeen off.
Run vinegar (1 cup) for a full cycle to help break down the lime and other build ups.
Check sprayer arm for debris and other objects. carefully pick it out with a small needle or sometimes even a nail works.
Try running dishes again to see if this helps.
May 28, 2008 | Miele 24 in. G665 Built-in Dishwasher
Help 3
you need to remove the lower panel on washer the pump pluged up the hose going to the pump from bottom washer can be removed but be aware all the water in washer will go on floor remove what ever in the pump put hose on put in to the spin cycle when done should open
Feb 28, 2008 | Washing Machines
Dishwashers Logo
44 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
