Question about Western Digital MY BOOK HOME 1TB EXT HD-USB2/FW/E-SATA 3.5IN 1YR FireWire 400 Hard Drive
Dropped the TB from about 2 feet onto the carpet...it lights up, does not open but requires me to remove hardware, it has everything I have ever done in the Army on it, plus pics....I have a 500GB drive as well and it works fine. I do not hear the click of death, but i do get the "installing drivers" then driver never installs, it times out basically. What is it going to cost if i have to take it to someone to recover data? can i do anything to recover it myself?
    President:
  • 1,187 Answers
Let's try to recover the data because the cost for disaster recovery is unreasonably high, approaching a thousand dollars.
Do not take the drive to any national computer supply stores/chains. The geeks will format the drive, if they get a chance to do so (and tell you to restore from backup).
These steps will not further risk losing your data.
You may also need to request "FixYa Premium Support".
Please keep in touch via comments or a new post and refer to "Gort007" if you need to contact me.
Read Options A and B completely before deciding which to do.
A. This requires opening up the unit.
1. Unplug all cables from the drive.
2. Open the WD World book
3. Re-seat the data and power connectors.
4. Check the connections again. Re-seat the data and power conenctions, again.
5. Carefully re-assemble.
6. It should work, if not do the steps in "B."
B. This does not require opening up the unit:
1. Purchase Avanquest Partition Commander ($50). Other experts may suggest a different or free utility. I trust Partition Commander.
2. Purchase a 500GB (or enough to copy your data) hard drive or another WD My Book, or any other external USB (or eSATA if your computer supports it).
3. Connect the NEW disk and delete all of the partitions. This is the NEW disk or external drive.
Do not create any partitions on it. The "Partition Commander" will do it.
4. Connect the damaged WD Mybook to the computer and boot the computer with the Commander CD.
5. A list of the disks will appear after selecting the default menu selections.
6. If the Mybook does not appear, then this option will not work until the steps in the "A." section above.
7. Copy the Mybook partition to the new hard drive.
8. If unable to do so, then try to browse the Mybook and copy folders to the new hard drive.
9. At this point yu may have to create a new partition on the NEW drive in order to copy your data to it.
10. If this does not work for you, please either do the seteps in "A." above, or explore Partition Commander more.
11. Partition Commander will triple check with you to be sure you do not do any steps that you didn't mean to.
12. Do not format your damaged drive, even after you recover the data. It is your ultimate backup.
-Gort007.
Posted on Oct 08, 2009
Dropped my HP D7 laptop. It slid out of my backpack from about 2 feet onto hardwood floor. On bootup, lights turn on for the keys and around the touchpad perimeter, and everything works fine with an HDMI...
You possibly cracked your screen or caused the ribbon cable to disconnect when you dropped it and just can't see what the error codes are saying. Is probably asking you if you'd like to start in safe mode with the beeps but you can't see it with a cracked screen or disconnected ribbon cable. Take it to a repair shop for a diagnosis.
Aug 29, 2014 | Computers & Internet
Hard drive was dropped 2 feet onto carpet and now not recognised by Mac Book Pro
If it will not detect in any way you try, then it is dead. Get another Hard Drive.
Jan 05, 2014 | Toshiba Computers & Internet
Hi my battery won't charge on my Sony Mavica...daughter dropped it about 2 feet onto carpet...charge light is flashing
the charge light flashing means the battery is damaged or very dead .. some charger will not initiate charging if the voltage gets too low ..thats a safety feature ... if those are the original batteries then they are past due for replacement anyhow ..
Jan 19, 2010 | Sony Mavica MVC-CD500 Digital Camera
I dropped my iphone and now the touch screen doesnt work
You broke it, sorry buddy but ull have to send it in and see if warranty will cover it for you (dont count on it)
Sep 22, 2009 | Apple iPhone 3G
Wet carpet
Your drain tube for the air conditioning is plugged up, and instead of draining on the ground, it's leaking on the carpet. You need to go under the car and locate the tube (it's on the passenger side, in front of and below where the front passengers feet would be. You will need a long thin wire to clean out the blockage.
Aug 25, 2009 | 2006 Dodge Stratus
We have a marrige ceremonyhallthehall dimentions are as below, toll carpet area=45'(feet)X82'(feet)=3690 height=10'(feet) glass area=5'(feet)X 45'feet=225 kindly provide the exact tonage required . re
what is the light wattage using in the hall the seating capacity,orientation,any other eletrical equipment,spot light,oops so may details missing???
May 31, 2009 | Coleman Mach III Air Conditioner
No power when the cover slides open
It is easy to remove the front cover. 2 small screws hold it on. Try cleaning the on/off switch underneath or it may need replacing if damaged.
Apr 24, 2008 | Olympus MJU 300 Digital Camera
DROPPED MY HARD DRIVE
well more that likely you disloged something in the case bu dropping it. What you need to do is open it up and see what has gone slack or disloged.. Its shoulden't require any replacement parts really as i dont think anything whould have been broken.
what you need to do it
open it in a clean enviornment which has little to no dust
and be careful not to break anything or soil anything while its opened
Jan 05, 2008 | Maxtor OneTouch II 300 GB Hard Drive
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Western Digital MY BOOK HOME 1TB EXT HD-USB2/FW/E-SATA 3.5IN 1YR FireWire 400 Hard Drive Logo
280 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
