Question about Samsung SGH-D500 Cellular Phone
Battery charging problem
Charging indication not functional, but battery is getting charged. When tried to charge in "OFF" mode, the phone switched "ON" automatically. Any solution ?
  • satrajit Dec 24, 2007
  • 137 Answers
Press *2767*3855# ,it completely reset your phone but most of the functions that doesnt work will work.
Posted on Dec 25, 2007
What is the function of the on/off switch. to save battery or to have on when charging and off when charging at the wall oulet?
On a cell phone it is to extend battery life when the phone is not required. Some phones will still retain some functions eg alarm clock, even when off. You don't need to turn the phone off when charging, but it will charge up faster if you do.
Mar 13, 2015 | Cell Phones
Phone says its charging when plugged in but battery doesn't charge
Hello and Welcome to FixYa!
Well, it seems like either bad charging connection. Look, sometimes, it happen, that as soon as you plug in the charger, the charging indication starts showing that the device is under charging mode, but in real its not. You can say, that the charging animation showing on the screen is fake. Secondly, it could be due to bad charging IC in worst case, or can be due to weak battery (in most cases), And to rectify the problem, first you need to try charging the battery with some other OEM charger, Secondly do make sure that there is no carbon deposition on the battery terminals. If the problem still persists, then either the charging IC or the battery is the bottle neck of the trouble. Hope, now you get a wider picture on how to deal with the scenario.
Have a nice day,
Concerned.
Aug 12, 2011 | Samsung Jet S8000 Cell Phone
Garmin 530 doesn't turn on
if the light goes off it would indicate that the battery is fully charged.
does the unit function like a phone when charging as in showing a chg indicator even if it is off? If so there are more serious issue than maybe just a bad power switch.
Oct 22, 2017 | Garmin Rino 530 GPS Receiver
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
K660i not charging the battery though indicator says charging
the the charger terminal, but the first thing is try to replace another battery
Aug 07, 2009 | Sony Ericsson K660i Cellular Phone
Whenever i charge my nokia 6680 it seems like its functioning as normal but after several hours of charging still the bar never stops charging. pls help
This is an indication of defective battery. Meaning that the battery could no longer hold a charge. Try charging the battery while the phone is off. If you get the same problem, try using another battery (if you could borrow).
You may also contact the manufacturer for second opinion.
Jul 20, 2009 | Nokia Cell Phones
Wont charge!
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
Aug 19, 2007 | Nokia 6300 Cellular Phone
It will not charge
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. click here Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. 5. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models. click here
Aug 16, 2007 | Nokia 6111 Cellular Phone
Phone won't charge
Hi, The Li-ion battery cahrging circuitary is some what complex. For most chargers, the charging procedure is divided into three main phases: ? Pre-charging phase ? Constant-current-charging phase ? Constant-voltage-charging phase In the Pre-charging phase, it utilizes low charging current to protect the battery. However,in most recharging situations, the charged batteries still have some voltage remaining, so the charger does not need to apply this action, and just passes it on to the next charging phase. The constant current and voltage charging phases are the main charging phase for recharging the batteries, where most of the charging energy is transformed into the battery. The maximum charging current for a battery depends on the battery?s rated capacity. For example, one battery rated 700 mAh usually can be charged at 350 mAh to 400mA, for faster charging effort. When the charged battery is Li-Ion, in the last charging procedure, the microcontroller normally maintains regular charging voltage while monitoring charging current to determine when the charging procedure should be completed. When the battery is fully charged, most of the electrical energy is converted to thermal energy, which can result in high battery temperature. In this case, the temperature monitoring function will be added for the solution. But since most Li-Ion batteries on the market also have an over-charging protection function, the temperature detect function is rarely used. So it is better to get your phone charging circuitary checked at a local store rather than to make a charger,coz both may cost you almost same. all the best my friend. regards sreejith
Jul 15, 2007 | Sony Ericsson K610i Cellular Phone
Samsung SGH-D500 Cellular Phone Logo
54 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
