Question about Dell 922 All-In-One InkJet Printer
Black cartridge missing message
I am getting the message saying the black cartridge is missing. I wiped the contacts on the cartridge and the cartridge holder with a damp paper towel, but the message is still flashing.
  • 708 Answers
The contact is bad and you will have to replace the catridge. I recommend just blowing it instead of using damp cloths, too late now. If you replace the cartridge it will take care of your problem.
Posted on Oct 08, 2009
Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I alrready replaced the ink cartridge but i am still getting the message "ink catridge missing or damaged". What can I do?
Did you refill the cartridge ? Most of the times when you get this error message it means the cartridge was refilled by the user instead of purchasing brand new ones or that the copper contacts (gold coloured strip) on cartridge could be defective.
Take a dry paper towel & wipe the copper contacts on the cartridge. Wipe the copper contacts inside the cartridge holders (where your cartridges sit inside the printer). Reconnect the power supply to the printer & try printing. If still doesn't work, call Lexmark Tech Support on 1800 332 4120. They'll fix your problem & in case they're not able to, they'd ship you a replacement cartridge, no charges at all. Its worth the wait on the phone waiting for the tech support.
Oct 31, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Officejet d135 says bad black printhead- Replace the pentagon --
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | HP OfficeJet D135 All-In-One InkJet...
It will not register the ink cartigdes.always showed 'low' from day one. put new cartirdges in black still says low. says color cartridge is missing..used to be able to bypass the ..won't print at all now
Aug 26, 2009 | Dell 948 All-In-One InkJet Printer
My canon pixma mp460 printer stopped printing. No message.
you change change your catridge, black and colour. try to clean it first your catridge with buying catridge celaner.
Aug 21, 2009 | Canon PIXMA MP460 All-In-One InkJet...
The printhead has a problem (after replacing the yellow/black ink cartridge with HP ink).
Try to clean the printhead manually ,
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Error in read the black cartridge
PREM
Apr 07, 2009 | HP DeskJet 3650 InkJet Printer
Paper mismatch error
PREM
Mar 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error problems wi Dell 626 all in one printer
Try these steps if this did not resolve try to clear the memory of the printer
and try to print ..
Feb 03, 2009 | Dell 926 All-In-One InkJet Printer
Lexmark 4530 right cartridge incorrect message. unplugged unit, cleaned cartridge nothing works.
The compatible cartridges for the X4530 Lexmark printer are the # 23,23A,24,24A,31,34,35. If you have the correct cartridge number and still says cartridge incorrect, try this steps.
1. Get a damp and a dry paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. ( try this for around 5 times )
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. ( try this around 5 times )
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Remove the power adaprtor behind the printer.
6. Using the dry paper towel, clean the metal contacts on the cartridge carrier inside the printer. ( try this 5 times )
7. Place the Cartridge back to the printer, connect the power adaptor.
8. Check if there is any error message. If same problem persist, try to contact Lexmark Technical Support.
Dec 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
132 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
