Question about Panasonic DMR-ES10 DVD Recorder
No power I have a panasonic DMR ES10. I was working the preceding day The device has been on a good surge protector and all other equipment on the protector are fine. What can I do to fix this?
  • 6 more comments
  • Kleanbore Dec 31, 2007
    I have the same problem. My Panasonic DMR-ES10 DVD recorder was a Christmas present in 2006. Last week it stopped working. There is no power at all, it is flat dead. The fuse inside is still good.
  • ozanota Jan 01, 2008
    Same fault - working fine one day, dead the next. Internal fuse fine. Help!!!!
  • jouk Jan 05, 2008
    I have the same problem but with DMR-ES15 instead. It stopped powering up on Dec 30,2007. Ichecked the fuse and it's good.
  • Anonymous Feb 09, 2008
    I purchased DMR-ES10 May 2005. February 2008 went dead. Will not power up. Fuse is good. I did not use it that much overr 2 1/2 years. Should have lasted much longer.
    rankinberk@aol.com
  • helpfix99 Jan 19, 2009
    I have the same problem, 2 days before it was working fine, went to use it today and it wouldn't power on, not displaying anything, no time shown. Tried different outlets, unplugging cord, nothing helped
  • Anonymous Feb 07, 2009
    Have the same problem.. No power... fuse still good... It happened when the remote fall in the floor.. Bizarre!!!!
    Bren
  • gieica Feb 23, 2009
    I changer capacity, but it is still not working. 5V and 16V DC is back, but the voltage on pin #1 on the connector between PSU to main board is jumping from "0" Volt to DL (on my DMM), once every 2 seconds.
  • HOWARDNC Mar 31, 2009
    My Panasonic DMR ES10 DVD recorder worked fine for about 3-4 years. For some reason, it could not be powered up. I read the solution and it sounded like you would need some electronic skill (opening the box and mess with capacitors) to fix it. If enough users having the same problem, should Panasonic provide some assistance or recall?
Mine died about 5 days ago, About Feb 5 09.
Fix was very simple. it involved a drill, a soldering iron, and spare capacitors.
Open up the unit. Spot all bad capacitors. in my case, a 820uf 10v ELNA capacitor was to blame, it had exploded adn opened up. Desolder the bad capacitor, Replace it with a good one, like matsushita or rubycon or nichicon. Random brands like CAPXONS and ELNA and Fuhjyuus are known to die fast. in my case, it got swapped with a matsushita. then the unit powered up again.
I found it funny that panasonic did not use a single one of their own capacitors in teh making of the unit. i spotted lots of Nichicons, which are really good, then lots of ELNAs which are bad, one Capxon and some matsushitas.
Posted on Feb 10, 2009
I'm sorry I can't suggest a solution but the same thing happened to mine on Christmas Eve! Seems that earlier posters had the same trouble on or near to the same day- surely not a built-in failure programme?!
Posted on Jan 02, 2008
I have a DMR-ES10 Recorder and after a power surge the power supply board is fried. I need a circuit diagram for the power supply please.
hi,
I have the service manual for Panasonic DMR-ES10 in PDF format. If you can give your email address then i will sent the manual to that. I can't up load the manual trough fixya as it a PDF file.
OK
Sep 21, 2011 | Panasonic DMR-ES10S DVD Recorder
I have a Panasonic DVD Recorder DMR-ES10 that will not power up. Are their any fuses on this unit?
hi,
every electronic equipments comes with fuse in the input side for protection .ur dvds power supply may have some problem. check it before inserting the fuse.
ok
Dec 17, 2010 | Panasonic DMR-ES10 DVD Recorder
Copyright Message on Panasonic DMR-ES10-S
certain files are decoded w/ copyright protection not all
Aug 13, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Mar 08, 2009 | Panasonic DMR-ES10 DVD Recorder
No user guide
hi....Download instruction manual of DMR-ES10 by clickiing this link http://service.us.panasonic.com/OPERMANPDF/DMRES10.PDF. It is PDF file and can be open / print through adobe reader . for adobe reader, go to www.adobe.com.
thank u
rate me
Feb 08, 2009 | Panasonic DMR-ES10 DVD Recorder
Instrucion manual dmr es10
Download instruction manual of DMR-ES10 by clicking Panasonic Support. It is PDF file and can be open / print through adobe reader.
Good luck.
Jan 14, 2009 | Panasonic DMR-ES10 DVD Recorder
Hot and Cold Conservatory
You should avoid extremes of temperature for ALL electronic equipment.
Sep 26, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10
std by light is on?means red light is on.If not than check fuse,vdr,and regulator ic in power unit.if fuse is open than change these component because fuse will blow if the regulator ic is faulty.
Dec 15, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr-es10 firmware?
How do I check the firmware on a DMR-ES10
Oct 16, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
295 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
