Question about Meade Optics
Etx-ls update to 1.2g failed, how to i restore or try the update again the autostar iii handbox does nothing
  • Anonymous Mar 28, 2014
    My telescope is 6 etx-ls. It has been out of use for some time and now the 'scope refuses to recognise the autostar 111 handbox. whrer can I get a replacement in the uk?
  • 3,186 Answers
Easy.
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software. To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar.
Posted on Oct 09, 2009
Why does the hand controller light up then goes dead
Possibly poor connection to the scope. Known issue. Go to
Weasner Mighty ETX Site for tips on repair
May 25, 2014 | Meade 494 AutoStar Telescope Control Unit...
I have six Meade ETS-LX 6" telescopes which are used in an introductory astronomy lab. I have upgraded the firmware and other files in three of the six and they are working fine. The other three do...
These scopes have many bugs in the firmware and are not a mature technology. Some people have issues and some do not.
About the only thing you can try is to reload the firmware using the SC CARD method. Contact Meade or read the manual to learn how to upgrade the firmware using an SD flash memory card.
Other than that the scopes will need to be returned to Meade for repair.
Mar 07, 2011 | Meade DS-2130 (350 x 127mm) Telescope
Message...Proc. trap 2 what does it mean ?
It means the firmware is corrupted.
It may be possible to reset it from software.
Try and reload the Autostar firmware from a PC.
(Download the updater application from Meade's website.
http://www.weasner.com/etx/autostar_info
http://www.meade.com/support/index.html
Feb 02, 2011 | Meade 494 AutoStar Telescope Control Unit...
ETX-80 hand controller say's "Self Check Failed"
You may need to reload the firmware by following these instructions for Safe Load:
From the Autostar 2.0 README file: "SAFE LOADER MODE IN YOUR Autostar:
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software (version release 1.1G and above). To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar."
This is for the 497 controller. There is NO safe load for the 494 controller.
Nov 01, 2010 | Meade ETX-80AT-TC Telescope
My telescope/autostar not working ,will only display startup info on handbox ,then nothing happens !.
This is sometimes caused by a bad hand controller cable and or corrupted firmware in the hand controller.
Get a new cable first and try it-- if this does does work then RESET the hand controller and reload the firmware using the proper computer cable and Autostar Updater Version 5.9 available here:
http://www.meade.com/support/auto.html
http://www.meade.com/support/Win7_ASU592_Installation.pdf
Aug 31, 2010 | Meade LX200GPS Telescope
I have a frozen autostar 497 handbox, can it be reset or saved? While doing an update, the updater program window asked if the handbox was in ''safe mode'' (I think it was something like that), I clicked...
Turn off the scope and plug in your computer update cable.
While holding down the ENTER key and the Scroll DOWN ARROW key on the bottom, turn the scope on.
The controller will go into Safe Load mode-- redo your update again.
Oct 12, 2009 | Meade Optics
Meade autostar hand unit fails after 2 seconds changed hand units
Does the Autostar start to come on then fail, ie you get the bleep and initial display, then nothing more? If so, it sounds like it is not completely blown.
I wonder if you need to reload the firmware? You can do this if you have a serial cable to connect it to a PC. To put the Autostar into "Bootstrap loader" mode, power off, then hold down the top left and bottom right buttons on the Autostar whilst you turn the power on (needs at least 3 hands!). The screen displays a different message and waits for new firmware to arrive up the serial lead. Look on Mike Weasner's site www.weasner.com/etx for full instructions.
Mar 04, 2009 | Motorola Mobility RAZR V3
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Meade Autostar handbox
removeformat.gifBecause this is a new purchase i would suggest getting the handbox replaced under warranty. If the guy was rude, then mention this to their management. There have been quite a few prolems with meade gear on our site here. Handbox included.
If you are up to it you can open it up. if so inspect the board for damage, shorts or loose solder joints. Some of these things can be repaired, some cannot. On this last statement it would seem sensible to get the replacement then start again from scratch. I have found about 7 recent problems with this unit, so be aware this is not a fault free unit.
nettiser
Sep 15, 2007 | Meade 494 AutoStar Telescope Control Unit...
Optics Logo
282 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
