Question about TallyGenicom 2265+ Matrix Printer
I have a TallyGenicom 2265+ printer with a Hardware Alarm
I have a TallyGenicom 2265+ printer that powers up with a Hardware Alarm +0255 +131--- 000000+0376+0268. Any help would be greatly appreciated on this matter. Thank you.
  • 21 Answers
Please try if a reset to default settings is solving the problem. To do this press and hold all 4 keys below the display while turning on the printer.
You may also check whether you have the latest firmware installed on your printer @ www.dascom.com
Posted on Jan 31, 2010
    Problem Solver:
  • 17 Answers
The 00000 code says that your board set is bad. There are 2 soulitions. First, replace the board set (duh), second repair the board set by replacing IC5.
Posted on May 30, 2014
Como puedo desbloquear el menu de una dataproducta 2265
Accendere la stampante tenendo premuto il tasto SETUP per sbloccare il menu
Oct 30, 2013 | TallyGenicom 2265+ Matrix Printer
LIPI 2265 printer showing hardware alram 0578
with out having all the numbers from your error code on the screen (most needed is the number ini the lower left) it is impossible to decode or decide what is wrong with your printer. more info is required. do not replace your logic board or your print cables. (rookie)
Oct 22, 2013 | TallyGenicom 2265+ Matrix Printer
I have a problem with 2280+ tallygencom printer. I have hardware alarm problem and with sense code +0001 +131 --- 000002 +2733 -0962 . Please help me . Thanks
The hardware alarm indicated is indicating a problem with print head movement.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
1)The printer ribbon is not jammed and is located correctly in the printer,
2)You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
3)You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
4)Also clean the thin transparent timing strip next to the carriage shaft.
5)With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the print head.
May 18, 2011 | TallyGenicom 2280 Matrix Printer
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
Hardware alarm 0036 131 000004 0376 0009 hardware alarm 0025 131 000004 0376 0009 hardware alarm 0024 131 000004 0376 0009
Hi, the printer seems to have a problem with the horizontal movement of the print head carriage. Turn of the printer and move the carriage by hand to check if there is an area where it can only be moved too hard. If yes, clean the carriage shaft from dirt, etc.
Sep 08, 2010 | TallyGenicom 2265+ Matrix Printer
Our tally 2280 Dot matrix has an alarm code 025609413032 What causes this to be displayed on the 2280 screen.?
check out this FAQ page for the hardware alarm codes:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=295%3Ahardware-alarms&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 19, 2010 | TallyGenicom 2280 Matrix Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Hardware alarm will not go away
It seems to be a gear problem . may some gears are not in proper position. function selection gears are not in proper position.
May 14, 2009 | TallyGenicom 7265+ 900 CPS GENICOM ANSI...
TallyGenicom 2265+ Matrix Printer Logo
748 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
