Question about Hobart D300 Stand Mixer
I have a Hobart 80 qt. stand pizza dough mixer that has lost forward speed, and only works in reverse. Is this electrical controls or a gear problem?
  • traboH Mr
    traboH Mr May 11, 2010
    Is this unit powered by a single phase or a three phase circuit?
  • 110 Answers
If the mixer is a 3-phase unit, that mixer has no reverse speeds, all gears should turncounter-clockwise when mixer is on ,if a 3-phase unit try switching any 2 of the incomingline to to change direction
Posted on Jan 10, 2010
Please can you advice why my 1st gear is no longer working but #2 and #3 is working. can you suggest what is wrong
The most likely cause is a faulty gear/gears or a faulty shift mechanism.
If you do not have experience fixing large mixers, I suggest calling in a qualified service technician.
Mar 04, 2015 | Hobart L800 60 QT Dough Bakery Pizza Mixer...
Hi, We have a 3phase Hobart D300 Mixer onboard and the cooks are complaining that there is not enough grunt. I have checked the 3 speeds and they are working finee however when dough is being mixed it...
Hello Veelec,
As the machine is mixing dough it seems that it is getting sluggish. This is caused by the machine being over loaded. Although it is a 30 qt mixer that is for liquid filled capacity. I do not know what kind of dough you are mixing so I will give you a light to medium dough and then the heavy dough capacity. Also on this machine all dough should be mixed in speed 1 or low to keep from damaging the machine.
You will need to know the Absorption Rate (AR) of you dough, to find this you take the weight of the water divide the weight of the water and multiply by 100.
AR = Water Weight / Flour Weight x 100%
The higher the percent the higher the capacity the lower the percent the lower the capacity. Also the temperature of the water will have to be considered as the colder the water the harder the dough it is to mix the dough the batch should be reduced by 15% to 20% for water temperature between 65-75 degrees.
For a Light to Medium dough with a 60% AR the unit capacity is 45 pounds in first speed.
For a Heavy dough at 55% the units capacity is 30 pounds in first speed.
The above capacities are for bread doughs, if you are doing pizza dough, dough nut dough or wheat dough please post back to this thread and I will help you to find the capacities.
I hope that I have helped you with your problem and would like to thank you for using FixYa to find a solution to your problem.
Mar 02, 2011 | Hobart D300 Stand Mixer
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
Jan 15, 2009 | Hobart D300 Stand Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
MIX7130
ship it back to anvil , buy a hobart ,best mixers in the world
May 19, 2008 | Anvil MIX7130 Stand Mixer
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Hobart D300 Stand Mixer Logo
271 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
