Question about KitchenAid Dryers
Everyting comes on timer light and power from on button but the moter want run
  • KitchenAid Master
  • 7,482 Answers
Sounds like your problem may be a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the problem is the motor then you will have everything disassembled so you can remove and replace the motor.
Good luck,
I hope this helps
Posted on Oct 08, 2009
When I turn the power button on the timer light flashes. How do I make the CD work?
Sounds like you need to turn the timer off, or leave it running until the timer finishes. Do you have the make and model? If not supply make and model.
Aug 04, 2015 | Audio Players & Recorders
I have connected the timer to the power source etc as directed. The red light comes on, indicating there is power--my model does not have a timer "on/off" switch so I cannot begin programming,...
You have to identify timer.
Say which buttons are on timer face and what wires the timer has.
What red light comes on?
Add a comment with specific information so I can identify the timer.
Intermatic, Brinks, Aube and UPM timers wire differently than other timers.
Swylightlight, Wattstopper, Leviton, Lutron, Woods, GE, Utilitec, Hagar, Sylvania, Westek, Intermatic (no battery) are generally wired in following manner:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect to timer-black-wire and timer-red-wire (sometimes this is blue wire). Choose either wire for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white wire to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground wire along with green wire.
5) Turn on electricity, and push ON-OFF button, or activation button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If timer is wired correctly, and timer does not work, then timer is defective.
Add a comment for more free help.
If you do not want free help, then take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 01, 2011 | Hardware & Accessories
How do u wire a three phase squirrel cage motor with a motor starter with a remote start/stop/inch station and warning indicator light ?
You would first run a conductor fromL1 to L1 on the motor start then run a second conductor from L2 to L2 on the moter starter, then run a third conductor from L3 to L3 on the moter starter. next run L1 and L2 to a step down transformer so you can reduce your working voltage to 120vac, then run a conductor on one of the outputs from the step down transformer to one side of the normally closed contacts on the STOP push button, from the other side of the stop button run a wire to one side of the start button, on the other side of the start push button run a wire to one side of the magnetic motor starter coil, the other side of the coil run a wire to the other empty terminal on the transformer, this will be the neutral wire. next you need to run a wire from the normally open contactor on the magnetic moter starter to one side of your push button start switch, then run one wire from the other side of the start push button switch to the other side of the normally open contacts on the magnetic moter starter, this is your start switch latch that will keep the motor running when the start push button is released.I'm not sure how you need the warning indicator light wired up, so please reply and let me know when it needs to come on and go off
Feb 04, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
My 4wd stopped working ...any ideas....when i hit the button for either auto 4wheel or 4wheel hi the lights on the buttons just blink and it never goes into 4wd just eventually the light goes back to 2...
check the fuse for transfer case shift moter if thats ok
check the connections at the moter then have someone push the button while use a test light or
meter to check for power if you have power at the
moter and it makes no sound odds are bad moter
Jan 11, 2010 | 1999 Chevrolet Blazer
I have an old Searsd Coldspot upright freezer, Thr
on the side of both defrost controls is a diagram black is normally power white is normally nuetral wire the black wire will go to the center of the switchs defrost heater
will be on one side compressor to the other white to the clock moter green was hooked to the metal case if you have a mutitester the clock moter will have constant continuity even after the timer has been turned till it clicks the heater will go on the contacts that have continuity for the shortest amount of time
on the back of most older units was a wiring diagram constant defrost has power even when t-stat is set to off
cumulative the defrost only has power when compressor is running the diagram on old defrost timer should be simaler to the diagram on the old defrost timer the lighter colered tab is normally white wire
hope you have a tester but if you are inclined hook up black and white only turn control till clicks when you have the black wire in the correct position the moter will run no matter where the control is turned
then find wire that starts compresser it will need to be placed on the switch that maintains contact the longest leaving the
heater wire to hook to the contact that stays closed for 20 to 30 minutes
most defrost controls wire the same be careful wiring is 120 volt
Dec 13, 2009 | Cell Phones
Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Jul 25, 2009 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
Need to pull moter out. does it come out the top or bottem?
If you are taking it out of a minivan, the easiest way would be to disconnect the entire front end (suspension) and lift the van - pull the old engine off, install new one, lower van, reconnect everyting. Check first to see if the cross memeber is welded on one side. I had an 87 Buick Century that I had another engine put into, and they were gonna take it from under the car, as I mentioned above, and when i looked underneath, the cross member was welded on one side, and bolted on the other. Very strange if you ask me. I think raising the vehicle (if you have a lift or jacks and jack stands to get it high enough. I hope this was helpful.
Apr 01, 2009 | 1999 Ford Windstar
Open Questions:
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
