Question about Fender Rumble Series 100/210 100watt 2x10 Bass Combo Amplifier
My fender rumble 100 used to cut out, now it's
My fender rumble 100 used to cut out from time to time. Then it got more frequent. Now it's just not working at all. In it's dying stages there would be a popping sound when the signal was lost. What is wrong with it?
  • PolyrhythmFX
    PolyrhythmFX May 11, 2010
    Have you checked the input jack's solder joints? Tried another instrument cable? Are you sure it's not your bass? Have you checked the connections on the speaker?
  • Fender Master
  • 5,603 Answers
Suspect the input jacks. Wiggle them and see if you get anything. They get yanked sideways because the musicians don't loop their cord thru a handle and they get yanked sideways.
Also you can try spraying sparingly CRC226 into the switches and pots. You can get it at Home Depot in the electrical department.
Posted on Oct 10, 2009
It plays for about 30 minutes and then just stops, as if overheating. After a cooldown period, it starts up again for another short period. Suggestions? Any recommended vents I could cut in...
The small Fender products often have a TDA2050 power chip in them. The chip is on a thin aluminum heatsink and is intended for light use. If you try to sound like a bass guitar amp with this, the chip will go into thermal protection mode. Cutting vents will not help very much, and pushing it to these levels will destroy the speaker eventually. If you need more power, buy a bigger amp. This one would be suitable for a 10 foot by 10 foot room.
May 24, 2011 | Fender Musical Instruments Corporation...
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Hello ! Do You have shematic diagram for bass guitar combo Fender Bass Rumble 100 / 15 ? If You have it, please snd me on my e-mail ? Regards Zlatko
Try this link:http://www.fender.com/support/amplifier_schematics.php If your amp isn't listed contact them and they will send you one.
Oct 21, 2010 | Fender Rumble 100 Bass Guitar Amplifier
What sound does the low mid suppose to give?
When terms like "low-mid" are used, it generally means frequencies between approx. 125Hz to 315Hz.
Apr 25, 2010 | Fender Rumble Series 100/210 100watt 2x10...
My Fender Rumble 25 makes a terrible crackling sound when the volume is turned up over the 4 or 5 mark. I don't think the speaker is blown as the same sound comes via the headphone socket.
Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Rumble_Bass_Schematic_-B21.pdf Check the tubes to see if one is loose in its socket. Do not attempt to repair this yourself unless you have amplifier repair experience as it is easy to get a bad or life threatening shock without the correct test gear and troubleshooting procedures.I hope this helps.
Nov 26, 2009 | Fender Rumble 100 Bass Guitar Amplifier
I have a rumble 100 bass amp which used to work fine until now! I've had it about 2 months and have only played it about a dozen times. Today, while practicing with a new band, 90% of volume got lost. Now...
It unfortunately sounds like a blown speaker. Try getting at the speaker and gently moving the cone with your fingers. If you feel a rubbing sensation you will most likely have to consider a new speaker. Make sure you get one with the same impedance (ohms) and the same or better power handling.
Jul 07, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Not really a problem want to know if I could add a extention speaker to the fender rumble 100 combo it has not ext. speaker out looking to add two 10 inch and if so how?
Hi there. If 10" speakers are 8 or 16 ohm, parallel them. If they are 4 ohm, series them. if "External speaker" output is rated down to 4 ohm. If no external speaker jack, you'll have to tap into existing speaker jack with a "Y". Check the minimum ohm load for the amp.
Thanks
Paul
Jun 03, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Fender Rumble 100 210 pop noise then hum after strong low e note
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Fender Rumble Series 100/210 100watt 2x10 Bass Combo Amplifier Logo
456 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
