No speaker sound. resoldered chips and started to work but problem returned
  • Jonathan Caldwell Oct 08, 2009
    gonna give it another try. thanks I will let you know if this works.
    President:
  • 1,884 Answers
You know the problem and the solution as well. Do it again. But the heating of the connectors may be harmful for the chip. So, if it does not work this time after re-soldering, then replace the chip.
Posted on Oct 08, 2009
Hello! I purchased this Labtec Speaker system about five or six years ago at Staples always worked great until I reinstalled Windows XP and the sound never returned. I do not remember it came with...
It's not the speakers that need the driver, it's the audio chip from your pc. You need to find out what audio chip you have - for that install and run this
http://www.cpuid.com/softwares/pc-wizard.html
then go to the site of the manufacturer of the chip and get the driver.
Apr 11, 2011 | Computers & Internet
The screen is fuzy when i first turn it on.then it goes black in about two minutes after about thirty minutes the sound dies out.
The tuner that is built into the board has developed solder cracks between the shielding and the main board. The tuner shield is part of the ground return circuit and needs to be resold-ed properly, left unchecked it will destroy the ep-prom chip and shut the set down.
Jan 26, 2011 | RCA F32705 32" TV
I have a GE 27GT624. The picture is perfect but the sound went out. Both speakers work fine when hooked up to something else. The circuit board looks like a resister and an E-prom chip has tan burn marks...
The epprom chip is most likely the problem, the tuner shield will need to be resolded to the main circuit board because over time it developes hairline cracks causing the epprom to fail in a variety of ways. The chip needs to be replaced and programed along with tuner shield repair, I don't think there is a board option replacement.
Dec 20, 2010 | GE 25GT240 25" TV
My picture is fine but I have no sound at all
If this tv is a couple of years old   it may need a sound chip replaced  or the tuner box needs to be resoldered or replaced   many new electronics have to be resoldered because of poor manufacturing techniques.   If it is new and you have a dvd player, satellite receiver, cable box etc hooked up you may need to play with different remote controls until the blocking device is unblocked  or the wiring may be slightly wrong
Nov 03, 2009 | LG 37LH20 37 in. LCD HDTV
Kenwood:1090VR Cracking sound from front speakers
There are poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Look for 3-legged transistors attached to small metal heatsinks, If you can solder, resolder the pins on those parts. Also look for any connections that appear to be grasiny or have rings and resolder them too.
Keep us posted.
Dan
Feb 06, 2009 | Kenwood 1090VR Receiver
Pioneer VSX-36TX popping and crackling during warm-up period
I have the exact same amplifier with what sounds like the exact same problem. I opened up the amplifier, and while it was powered on started tapping around until I heard the popping and crackling suddenly increase. I was using a piece of wood and the plastic part of a screw driver for this. The popping and crackling suddenly burst out onto all channels when I was tapping on the DSP board (encased in a metal enclosure to the very right of the amplifier).
I took off the metal enclosure (with the receiver turned off, of course :), and with the receiver on, and started tapping around the DSP board, and I found that the biggest crackling effect was achieved when I tapped on the Cirrus Logic CS493292-CL chip which does all the decoding and switching.
I detached and took out the DSP board and looked at it very carefully but of course couldn't find any bad connections. I tried resoldering all the feet of the Cirrus Logic chip and many many components all around to no avail.
Finally I tried applying pressure to the chip while the popping was going on, and it stopped. Further investigation revealed that bending the board around the chip produced the same effect.
For the life of me I couldn't figure out why bending the board eliminates the problem, but my solution was to put a piece of eraser wrapped in masking tape and taped to the Cirrus Logic chip, and two other pieces on the back of the board in such a way that when the metal enclosure was replaced onto the board, it put gentle but firm pressure onto the Cirrus Logic chip and at the same time bent the DSP board slightly.
It's been a few days without popping, clicking or static, but time will tell. Good luck!
Oct 31, 2008 | Pioneer VSX-36TX
Panasonic Dvd Home Sound system SC-PT950 code f61
The F61 is the coded "protect mode" indication. The internal amp chip has failed. It sounds like this system should still be under warranty. Return it for warranty service. The amp chip will be replaced.
Sorry about hte delayed response. I was away in business for a few days.
Dan
Aug 03, 2008 | Panasonic Home Theater System System
DENON AVR-1905 centre channel dropout
I have seen this a few times. Try resoldering the pins on the voltage regulators. If you are not comfortabel with that, bring the unit to a service shop and report the problem as intermittant. Have them resolder the regulators and the surround output amp chips. This should cost only a minimal labor amount. That may resolve the problem. If not, then we'll need to look into the surround processing circuitry.
Dan
May 08, 2008 | Denon AVR-1905 Receiver
No Sound From a Denon AV Amp
maybe your speaker are busted tyr to check it...the connection of the speakerwire sometime may be lose...or try check the wire to speaker by the tester, if had a rading continuity
Feb 29, 2008 | Audio Players & Recorders
24 people viewed this question
 Grubhead
Grubhead
