Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
Gateway will not connect to simpletech 250 - SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive
Posted on Nov 22, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
SimpleTech will not Connect with Window 8.1
Troubleshooting tips for external drives here
External Drive troubleshooting
Certainly seems worth looking at the drivers!
Nov 01, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
I've met space limit for my SimpleTech external drive even though my internal drive still has space and both are 250 GB. Are there SimpleTech programs taking up space and if so how much of that 250 GB...
Your internal drive is different than your external drive. If you put more files onto your SimpleTech drive, then that one is going to fill up faster. The best thing to do would be to go through your SimpleTech drive and delete anything that you don't need. I don't remember my SimpleTech drive coming with any software on the drive, but if it did, it didn't take up much space.
Aug 21, 2011 | SimpleTech Signature Mini 250GB External...
Where can i get the installation softare for simpletech 250???
you can check on the official site from here http://www.simpletech.com/commercial/products/simpledriveexternalpininfarina.html ;you need to plug in USB to be recognized by you PC or laptop after that you can acces your hard drive when is instaled make a reboot to be sure that is instaled properly.
Dec 10, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Error code 16
Code 16 is a hardware or firmware failure you need to Surf a little and reveiw the home page. Hold on ill get the address to take you too the solution
http://www.simpletech.com/support/support_downloads.php
This may resolve the problem and grant you access to your HD
Oct 18, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
No software or instructions
simpletech is a plug and play device compatible with vista and xp. you dont need a software to use it unless you wanted to access the quick backup button function when you press the simpletech logo. software is available at their support website: www.simpletech.com/support/
Jul 16, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech Hard drives blue light wont turn on for some reason. Basically the whole thing is off even when i plug it in and turn on the switch i get nothing.
You will probably have to dis-assemble the drive from the enclosure and connect internally to yoru computer to test to see if the drive is good or not.
Or it could be the power cord that has gone bad.
Jul 14, 2009 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
66 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
