Question about Krups FME2 Coffee Maker
Krups coffeemaker will not work. When I turn it on it just beeps. Display blinks double horizontal lines. Tried to descale it but again it won't start so can't get solution to run through the machine.
I have the same problem. The coffee makers believes there is no water in the machine, though I know there is.
Posted on Jan 03, 2010
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
PROBLEM WITH XP2070 KRUPS ESPRESSO MACHINE
try descaling again , and perhaps 2 or 3 more times some places the water being really hard it takes more than if good water is used
Jan 29, 2018 | Coffee Makers & Espresso Machines
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
FME4 won't brew; thinks there's no water
I believe that the description you made of the horizontal dashed lines indicates that the unit needs a descaling. If it also says "CALC" on the LCD display, then that probably means that calcium build-up needs to be removed. I am looking for my instruction manual because my machine is currently doing the same thing and in the past I've followed the instructions to descale it using a solution of water and vinegar. The weak acid from the vinegar removes the calcium deposits in the machine. Use distilled water and you won't have to descale it!
Jun 12, 2009 | Krups FME4 Coffee Maker
Need Manual for Krups coffeemaker AG E 15 - can't set time
I went to the Krups web site and pulled a copy of the manual for a different model with the same user interface. This solution worked fine. My model (on the baseplate) is AG E 15. The manual that I printed was for a FMF5. Cheers!
Mar 30, 2009 | Krups Small Appliances Espresso Machine
Krups FNC3 Espresso Machine
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Aug 01, 2017 | Krups Novo 3000 /FNC3 Espresso Machine
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
XP 2070 Won't Stop Beeping
Okay, I had the same problem, started beeping and lights flashing one day, unplugged it and it was okay for a few days then this started happening more often until the machine just beeped and blinked all the time and would not make espresso. When I called Krups customer service I was told it sound like a circuit board problem and to send it in, yes its under warranty but I have to pay shipping both ways, so I decided to check it out myself. So here is the bottom line and what worked for me, I removed the espresso screen (above coffee grounds holder, 1 phillips screw) and ran 4 tank fulls of descaler thru the machine. the hard part was getting it to pump thru the machine. I found if I ran water thru the hot water/steam nozzle first I could get it to run 1 or 2 cycles, I also found that by removing the water tank and turning the system on for a few seconds and running pump dry (not recommended) I could get it to cycle without blinking for a few turns. Ran the 4 tanks of descaler thru, then ran 4-5 tanks of water thru into a bowl until it ran thru clean. The machine is 4 months old and I was shocked at the amount of crud that came out. It now runs fine and no more blinking, If indeed this is the fix for this you would think someone at Krups would have a clue, but I guess there a useless a the owners manual for the xp2070.
Thanks and I hope this helps.
John
Apr 24, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Oct 30, 2007 | Krups ProAroma 453-42 Coffee Maker
Krups FME2 Coffee Maker Logo
2,100 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
