Question about Acer Aspire 5520-5579 Notebook
Windows Failed to start File :BootBCD Status:0x0000098 Info:The windows Boot configuration Data file does not contain a valid OS entry . this is the first time i am having problem with my laptop from last 11/2 years ,i dont know why suddenly this appears !! please need some help
    President:
  • 2,600 Answers
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 08, 2009
Boot up xp get the.... File:\Boot\BCD Status:0x0000098 Info:The windows Boot Configuration Data file does not contain a valid OS entry.
try putting your XP disk in the drive and shut down then restart system many times it will find what it needs and go to working again
Apr 17, 2015 | Computers & Internet
My rebooted my advent 4211-b netbook to factory setting by the tech guys on the netbook but now my netbook wont start up, it says the window boot configuration data file does not contain a valid os entry
Welcome to Fixya
Error means the boot files are missing or damaged. Try to restore the computer using the disk that came with it instead of using the recovery console.
Thank you for using Fixya!
Sep 26, 2011 | Advent 4211c Notebook
Advent netbook wont start up after being rebooted it say the windows boot configuration data file does not contain a valid os entry
Problem is generally caused by a disk error. If you can connect the disk to another computer and run CHKDSK /F it might fix it.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 26, 2011 | Computers & Internet
Hi, I have an Advent 4211b and tried to run Tech Guys systems Recovery. Now it keeps loading into Windows Boot Manager, where it tells me that windows has failed to start, It gives the following...
I can't help you recover from the problem, but I can tell you what the problem is. What is happening is, when you tried to recover, it messed with your boot partition for your install. You probably tried to restore a partition. So, what happens is when windows tries to start, it is getting references to software that is not where it should be, or more to the point, not configured with the correct registry entries.
Your best bet is to wipe the drive completely, run a clean windows install and then restore only the files you need restored. That way it will not try overwriting your boot partition again.
I hope this sheds some light on the situation. Good luck!
Sep 03, 2017 | Advent 4211c Notebook
File: \Boot\BCD Satus: 0xc0000098 Info: The windows Boot configuration data file does not contain a vaild OS entry. I have a windows installation disc
boot to the Windows DVD, select the option to REPAIR, If this is only a software issue, that should resolve.
If it doesn't then run diags on the HDD is it may be failing
Jan 15, 2011 | Computers & Internet
What is file error 0xc000000e
File: \Boot\BCD
Status: 0xc000000e
Info: An error occurred while attempting to read the boot configuration data.
Windows failed to start. A recent hardware or software change might be the
cause. To fix the problem:
1. Insert your Windows Installation disc and restart your computer.
2. Choose your language settings and then click "Next"
3. Click "Repair your computer"
If you do not have this disc, contact your system administrator or computer
manufacturer for assistance.
ERNZ
Feb 03, 2010 | Toshiba Sattelite A105-S2051 Notebook
Advent 4211c will not turn on atall it says windows boot manager...windows failed to start and i do not have a windows installatin disk. how can i sort this problem out if atall .this is the only thing...
This is a boot config problem.
The fix will require that you have the Windows XP cd. Maybe you can borrow one from a friend in order to fix this. Once you have the cd, navigate to the following link for step by step instructons.
http://www.webtree.ca/windowsxp/repair_xp.htm#How%20to%20Repair%20the%20Boot%20Sector:
Sep 24, 2009 | Advent 4211c Notebook
RESTORING WINDOWS/BOOT MANAGER
Sounds like you have Vista. Here is a link on creating a Vista recovery cd:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
This link is a how to document on repairing the BootLoader:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+with+EasyBCD
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Open Questions:
Acer Aspire 5520-5579 Notebook Logo
1,085 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
