Question about Epson Stylus CX4800 All-In-One InkJet Printer
Will linksys wirless g print server woork with epson cx4800 printer
    President:
  • 1,187 Answers
Yes,
This is a USB All-In-One printer and the Linksys Wireless G Print Server supports USB pprinters.
However,
For the cost of the Linksys print server, you can purchase an Epson NX515 that has built-in WiFi. It would also be less hassle if the Linksys/CX4800 has a problem. You would not know which device is causing the problem.
Posted on Oct 08, 2009
I jus got a printer the epson stylus nx125 an they said wit was wirless.. but its asking for a usb connection. is it not wirless?
It may need a USB connection to do the initial setup. Afterwards, it may be wireless. Thanks for using FixYa!
Aug 22, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
Just loaded new ink , the printer does not print and if it does the paper is blank .
Go to printer and faxes, and right your printer Epson Stylus CX4800 and click printing preferences. Go to maintenance tab and click head cleaning and repeat if 5 times and also print head alignment.
Nov 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Is the Epson Stulus CX4800 a scanner, printer, copier?
Epson Stylus CX4800, is a all in printer. It can scan,copy and print. Thank You.
Jun 17, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Epson cx4800 ink light is on and will not print
do a powerflee
1) unplug all cables including power cable.
2) press and hold the On/Off button on the printer for 20 seconds.
3) plug back the cables and try printing.
May 07, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson cx4800
How is the printer connected to your computer?
What is the operating system of your computer?
What are you printing specifically?
May 24, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
213 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
