Question about Jwin Audio Players & Recorders
I've plugged in two desktop speakers into PC they don't work
I've plugged in two desktop speakers into their corresponding connections at the back of the pc, restarted the system, once the pc was ready I tried playing a sound file, only to get an error message, saying, "There's no sound devices connected, please advise :o)
  • 62 Answers
The problem is that you haven't installed the proper audio drivers in your system.
Have your audio driver installed and then try to restart your PC.
Posted on Oct 08, 2009
My left speaker is not working and it isn't the cable connection. It has been checked and the plug is in all-the-way.
You could just have a loose wire inside the speaker but sometimes one speaker will just go to speaker heaven. Sorry I can't give a better answer and I don't know that brand so I don't know if you can open up the speaker easily to see if there is a loose connection. Now, sometimes the plugs can just wear out too which can be replaced if it is a great set of speakers but again, back to the lack of knowledge about that brand and how hard it is to work on.
May 22, 2012 | JBL Audio Players & Recorders
I've problem with interanal speakers in Asus VX2S - don't work - externals work fine
It might be a cause of Loose connection or damage of your laptop speakers. Its a hardware problem. Check your Connectivity of Speakers on the motherboard. It might work!
Sep 01, 2011 | ASUS Lamborghini VX2S-B1Y Notebook
I'VE SUCCESSFULLY INSTALLED MY SOUND CARD (C-MEDIA CMI8738 FOR XP) AND I SEE NO CONFLICT WITH OTHER DEVICES ON MY PC BUT I DON'T HEAR A SOUND FROM MY HEADSET WHEN I TRY TO TEST TO PLAY A MUSIC....
I'm assuming that the previous audio drivers have been uninstalled. The card must be made aware that you have speakers and/or headphones plugged in. First open Control Panel > Sounds and make sure the volume is set at maximum and the correct setup is selected - stereo , desktop speakers. Then take out whatever you have plugged in it, reboot the pc, wait for everything to stop (antivirus update, the launching of all the programs) then open the C-Media Power Mixer and verify in there that all the volumes are at maximum. Then connect the plug in the green socket of the card - a popup should appear to ask you what you plugged in. If it doesn't then you will have to do it manually:
Aug 16, 2011 | Computers & Internet
Im plugging in my nic and there are two plugs instead of one which is pink.which green plug does it go to and where does the speaker plug into?
Plug them into the corresponding green and pink jacks.The pink is for the mic and the green is for the headphones.
Aug 10, 2011 | Dell Dimension 4600 PC Desktop
I cannot get a sound from my pc. where do i connect the speakers
If the speakers has the common round 3,5mm jack you have to plug it in the green hole at the back of the power. If the speakers has a USB connector you have to put it in any available USB connector at the front or back panel of your computer's tower.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 02, 2011 | Compaq Presario SR5710Y PC Desktop
Dontno sound on speakers
Make sure the speaker cable from the speaker is connected to the speaker plug on the machine, usually green. If the speakers have an AC adapter make sure it is plugged into the wall outlet and to the speaker. Make sure the sound card is configured and working correctly. Make sure you don't have the sound muted. I hope this helps. Good luck and have a great day.
May 01, 2011 | Dell Dimension 2400 PC Desktop
We recently moved and now I have no sound I don't think anything was changed when it was hooked up
When you unplugged the speakers the pc forgot they were there so when you plugged them back it ignored them. To make the pc aware of their existance again unplug them, open the Realtek Control Panel RTHDCPL.exe, go to the Audio I/O tab an plug the speakers back - the corresponding jack  from the CP will light up and a new window will appear asking you to select what you have plugged in - select Line Out and OK.
That is all, now you have sound again.
Jun 26, 2010 | Dell Dimension E521 (D10E16) PC Desktop
I just bought the logitech LS21 speaker system for my dell and there is a subwoofer and then a left and right speaker to hook up. Where do i plug the subwoofer in at on the back of the compuer and where do...
The set up should be as this.cable plugs into headphone jack on your pc. that connectects to your powerd subwoofer it is power correct! then your small speakers connect to the sub box or thew should? look on the sub box usually front and on the bottom.if thee actual speaker connections then they will be on the rear.
Jun 11, 2009 | Dell Dimension 4700 PC Desktop
I can not hear anything through my computer speakers. Website sounds, music, or the AOL welcome message. I can only hear if I connect a set of earphones
There should be an audio cord which is green at both ends one end should plug to the corresponding port in bak of your monitor the other should plug into the corresponding green port on your tower. If this doesnt work it may be a compatibility problem.
Nov 27, 2008 | HP Computers & Internet
I've just bought a desktop from Cube (the Polaris ST12) which comes with Creative Inspire T6100 5.1 speaker system. The connection instructions which come with the speakers show 3 cables from the subwoofer...
The blue is for a audio in and pink is the mic. Green is the audio out.
You will need to buy a new video card that has all 4-5 colors (green,,black,orange,blue,pink,white)
That way you can plug in all your connections and it'll work correctly.
Oct 23, 2008 | Computers & Internet
115 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
