Question about Jenn-Air JDS9860AAS Dual Fuel (Electric and Gas) Kitchen Range
I have a JDS9860AAP stove. Red flame on lpgas after few minutes
I have a JDS9860AAP stove. I have nade the change-over to LPgas as recommended in the manual. I have also replaced the leftside grill with with the sealed burner module. My problem is that on light-off the rear burners in particular start with a nice blue flame with red tips but after a few minutes deteriorate to a very red flame as if from air starvation. The air ports are fully open. The right rear is most severely affected. I have tried removing the lower housing of the burner, shimming the top of the module to get more air to no avail. Solution?? thanks in advance. Gerry
gwil45@yahoo.com
SOURCE: will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Posted on Feb 13, 2008
Skill Will
  • 53 Answers
SOURCE: lpgas oven
hi,
this could be servel different problems, most of which are fairly simple. however, with LP you may be better off contacting your LP gas supplier to see if they can check it for you.
Posted on Mar 24, 2008
aborcass
  • 2651 Answers
SOURCE: Burner controls
if you remove the knobs from the unit nad look closely doen the shaft of the protruding valve stem you should be able to see a slot for a regular screwdriver to fit down, its gonna have to be long adn thin but that is the flame adjustment screw,
put the flame down to low and use a pair of pliers to hold the valve stem from turning as you try to adjust the screw, turn it very slowly you seel an adjustment happen (dont really know if its counter clockwise or clockwise, but youll figure it out playin gwith it for a bit, just remember to hold the shaft from turnig, and although your turninf the valve down to simmer it does not afffect the high setting
Posted on Apr 06, 2008
SOURCE: Installation
I have a jenn air gas range with a convection oven and want to convert it to propane, but can't get an instllation manual to find the part numbers or instructions.
How do I get them?
Posted on Sep 21, 2008
SOURCE: igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Posted on Dec 31, 2008
Ihave a glo-ray free-standing rinnai heater.LPgas iwould like to change it with a NG kit #pc104f -1-4.7 assy#66n
the only difference between lpg and ng is the jet sizes in the burbers. you can get the jets from any BBQ shop. when fitted adjust the air shield around burner inlets to correct for the different gas . Moving the shiels in or out changes the air /gas mixture to give blue flame.
Dec 31, 2014 | Grilling
Where can I download a user manual for the Model OSD-60L stove and we lost the wind shield that goes around the stove as well...where can I get a replacement? thanks
Unfortunately, there's no online manual for any of the Camp Chef products. However, you can call them directly 1-800-650-2433, and they can email you one as an attachment. Plus, you can also purchase a wind shield from them at the same time. They,re good folks to work with and they look after their consumers
Hope this was of help to you..
Jul 13, 2011 | Camp Chef EX-60LW (LP) Grill
Just put in a new Caldera LPGas cooktop the flame is yellow and putting soot on pots how can I adjust air to correct this?
you stove may have jets for natural gas rather than bottled gas the calorific value of natural gas is different to propane and the jets are larger because of this. if using bottled gas then you will get yellow flame and soot because there is too much gas to burn properly check your installation manual for procedure to change the jets for each gas
Dec 19, 2010 | Stainless Caldera SSK-305 Steel Gas...
I don't have an instruction manual for my Coleman grill stove #9921. Is it possible to get one? Thank you.
Sure! Go here http://tinyurl.com/28k8shq select the item you are looking for a manual for, enter your model and download a free manual.
Nov 06, 2010 | Coleman Propane Grill Stove 9921-700
How do you remove the burner part of a coleman grill/stove? I trying to give it a good clean. I got the 4 screws off and grill fuel bar, but for the of me, how do you remove the burner part. Kelly
The Coleman website has a pretty excellent list of owners manuals. (Here's the link for the 9921A700)
I believe that you unscrew the burner assembly on the right, which will then let you remove the cooktop to clean inside and re-assemble.
This procedure is not listed on the Coleman website or in the owners manual, however it appears to be fairly straightforward. I'd recommend using some teflon tape on the threads when screwing the burner assembly back on.
Aug 18, 2010 | Coleman Propane Grill Stove 9921-700
I have no instructions for my stoves envoy cooker, need to know how to set 3 button timer and grill wont ignite, help!
You can ring stoves on 08712222502 they will usually email over a manual for free you just need your model and serial number of your oven.
This can be found usually just behind the door to the grill.
hope this helps :)
May 19, 2009 | Stoves 850DODLM Gas Kitchen Range
Schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Will not cook properly with downdraft vent on. JDS9860AAP Range
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDS9860AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
110 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
