Question about APC Smart-UPS 1000VA UPS System
When i press the test bbutton,all the lights are coming on
  • 108 Answers
Check the battery voltage
Posted on Oct 08, 2009
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Tip
Increase the speed of statrt menu button
This tip is for the increase speed of start & menu bbutton .It's so simple the steps are as fallow's
1) Press statr button.
2)Go Run & write "regedit".
3)HKEY_CURRENT USER & then control panel
4)Double click on "Desktop".
5)Double click on "Menu show delay".
6)change it's value from 400 to 0 then press ok.
7)Restart u'r computer. Go on start panel see the magic
on Feb 05, 2008 | Microsoft Windows Vista Ultimate Edition
Changing Region setting
most dvds alow one change after that they fix on the last setting easier to got o a website like hacksearch and set it to all regions permanently I did with my SAMSUNG and it was just a matter of pressing the bbuttons on the remote in a set sequence It also plays dvds
vcds from anywhere now
Jun 06, 2012 | Televison & Video
There's no signal to my monitor when i press the power button,and sometimes it just keeps coming back on when i try to press the bbutton to take it off
have you checked all the cables from the computer to the monitor,, if there all connected correctly
then you might want to have a computer tech check the machine, it could be a cable, or motherboard or harddrive or power supply going bad
Sep 22, 2011 | E-Machines T6212 PC Desktop
My dell inspiron 1525 laptop is not switching on
unplug the power cable and take out the battery, then press and hold the power bbutton for 30-35 secs. Insert the battery and plug the power cable, check if it works!!
Oct 18, 2010 | Dell Inspiron 1525 Laptop
I accidentally push the reset button and my laptop won't start
Oct 18, 2010 | ASUS A9RP Notebook
96 suburban brake ligh don't work
you may have to change the brake light switch at the top of the brake pedal stop by your local GM dealership in the parts department and they be able to print you off pictures and diagrams but check on the part at your local part store because it maybe cheaper wish you the best of luck Michigan Man.
Dec 27, 2009 | 1996 Chevrolet Suburban
Can't receive faxes
The problem is in the recieve mode you have it set to tel/fax you need to set it to fax if yu have it on auto or te/fax if you pick the phone up you have to press the start bbutton to get the fax through if you are only using it as a fax set it to fax .. it will then go strait through.. good luck..A
Jun 27, 2009 | Brother IntelliFax-2820 Laser Fax
Power button
answer miines and ill help you. try reseting it. hold down the play bbutton and get a paper clip and put it in the little hole in the bottom and reboot it.
Aug 24, 2008 | Dell Pocket DJ MP3 Player
APC Smart-UPS 1000VA UPS System Logo
122 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
