Question about Samsung RS2630SH Side by Side Refrigerator
Replacing ice and water levers
How do you access the inside of the freezer door were the levers are for water and ice on a samsung rs2630sh.
  • RalphPruitt May 11, 2008
    Hey....I need the same solution...I am trying to get at the Ice dispensing arm to fix the switch mechanism which I believe is stuck. I can't perform the repair because I have no idea on how to get at the mechanism without breaking the the plastic cover. What is the procedure. if I can't solve soon I am sure I will just break down and buy the repair manual.....
  • Anonymous May 27, 2008
    BOUGHT THE ICE LEVER BUT CANNOT ACCESS BEHIND FREEZER DOORS. I LIKE SOLUTIONS WITH LOTS OF DETAILS.
    Genius:
  • 1,224 Answers
Behind freezer panel on the seal strip there is usually plugs or screws to pull inside panel off be gentle cause the plugs are not easy to recover or buy at a store
they you have bottom hold screws 2 to 3
these doors are siliconed in so be careful when pulling freezer panel
front panel plate has 3 hold in screws be gentle here the fron panel pulls out be gentle
Posted on May 13, 2008
I have a samsung cool n cool american style fridge freezer with two tabs on the front. One for cool water and one for ice. The water works perfectly but no ice is being made to fill the bucket, why is
If the refrigerator water dispenser (or ice) is not working correctly the water supply tube(s) may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined (this is most likely the culprit) , third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch (try this first), when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Mar 30, 2014 | Samsung Refrigerators
Ice maker water not coming out of the outside , no water supply to the ice maker
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
Jun 22, 2011 | Samsung RS2630SH Side by Side Refrigerator
My samsung rs2630sh, has water pooling at the bottom of the freezer. Water will also leak out of the until onto the floor. the ice buit up so much had to break it up just to get the bottom tray out. Any...
I have the same problem. Water from the defrost coil is not running out the outlet, but freezing in the defrost "catch" pan and outlet tube. Once water freezes, then water from subsequent defrost cycles, runs into the freezer floor and eventually out to the front or side. I don't have a permanent solution, but you can take the inside panel off with the four screws and see the problem. Chip out the ice dam and clear pathway with very hot water. I have read that lowering the freezer temp may prevent. Open to new ideas or permanent solutions. Good luck!
Mar 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
Freezer side tmp flashes/makes noise/inside back panel iced
The freezer side is off. The temp is flashing on the meter in front of the refrigerator. This is a Samsung RS2545SH. Does this freezer have a reset button or what shall I do.
Jan 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
Freezer constantly produces ice buildup along the vents and fan blades inside are striking the ice buildup. Why wont the unit defrost? Also produces large chunks of ice from the ice maker during this time....
SAMSUNG REFRIGERATORS ARE KNOWN FOR DRAIN ISSUES., YOU NEED TO DETERMAN IF ITS FROST {DEFROST PROBLEM} OR ICE {drain issue} IF ITS ICE YOU SHOULD EMPTY IT AND UNPLUG OVERNIGHT WITH THE DOORS OPEN. IF FROST YOU SHOULD CALL FOR SERVICE.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 14, 2010 | Samsung RS2630SH Side by Side Refrigerator
Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Aug 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
101 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
