Question about Dell Dimension 2400 PC Desktop
Dimension 2400 tower keeps making a
My dell dimension 2400 keeps making a loud "clicking" noise intermittently in the (drive ?) tower part...............just like the sound it makes just before it finally goes to idle on shutdown. There is no particular pattern as to when it will do it. i.e. happens when not using and also when using internet, email etc but is getting more frequent than previously. Anything to worry about ?
    President:
  • 2,600 Answers
Here is a test for it. Go to the start button > programs > accessories > system tools > disc defragmenter. Run a defragmentation on "C" drive and see if you can hear a lot of clicking, Normal hard drive activity will sound like rapid fires clicks but should not be incredibly louder than you are used to. If there has been an increase in the volume of the clicking sound that is out of the ordinary, then I would guess that the read/write head on the hard drive is starting to fail. and that sound you hear may be it slamming itsefl back oand forth as it is reading the discs. I would venture to say that having a bootable backup may be in order or at least an external or flash drive to save your documents, pictures, music...etc.
Posted on Oct 08, 2009
Dell Dimension 2400 won't boot says press F1 continuosly and hard drive makes constant ticking noise
there could be a problem with your hard drive. I would try another one if possible.
Nov 07, 2012 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 keyboard and mouse and monitor not working
i think its a hardware issue so you should contact to dell care..
May 05, 2012 | Dell Dimension 2400 PC Desktop
How to remove computer cover
Try this website..this is a manual for Dell Dimension 2400 PC Desktop
it includes how to remove the cover of your tower. Check it out..
http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
Sep 14, 2010 | Dell Dimension 2400 PC Desktop
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension 4700: top fan makes a lot of
some fans are just loud, they tend to speed up and get louder when the computer heats up, it keeps it from over heating... if it always runs hard and loud the internal thermostat could not be working right.
Feb 23, 2010 | Computers & Internet
My dell dimension 2400 goes on standby automatically.
If the power LED on the Tower is blinking amber, then most likely the power supply in the tower is failing. Replace the power supply.
Dec 31, 2009 | Dell Dimension 2400 PC Desktop
Hello I have a Dell Dimension 3100 desktop. After
Bad Fan... either the CPU Fan or the Power Supply Fan or the Case Fan. If the PC is older than 4 years it is probably the Power Supply.
Dec 30, 2009 | Dell Dimension 3100 PC Desktop
How do you open the tower of a dimension 2400 tower
If you look at the CPU from the back. On one side usually the left you will see a screw where the side wraps around the back. Some brands will use two screws. Remove this screw and then you can slide the side panel back toward yourself. Then you can turn the CPU exposing the open side. While your in there (make sure the unit is not plugged in) take a can of compressed air and clean your cooling fans and vents. Keeping a computer cool is important to keeping good performance up to where it should be.
Sep 30, 2009 | Dell Dimension 2400 PC Desktop
D drive onj dell dimension 2400 will not open...
Using a small needle their should be a hole in the front. This is the safety eject hole that will open the drive 99% of the time. Replacing the drive is just as easy. remove the few screws on the bottom of the laptop nearest the drive and grasp ahold of the bay and slide it away from the computer....hope this helped some....
Kevin
Jan 31, 2009 | Dell Dimension 2400 PC Desktop
HOW DO I REMOVE COVER OF 2400 TOWER,INSTALLING 80G HARD DRIVE
Here’s a link to the service manual for 2400: http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
128 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
