Question about Canon imageCLASS D780 All-In-One Laser Printer
When copying paper is not pickup from the tray
  • 56 Answers
Pick up rollers dirty or the shaft is miss alighned and there is a fix for this where cannon has a part number for it and it is FG6-9554-000 which is called the Retainer shaft maintanance kit.
Posted on Oct 09, 2009
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Printer will not pickup the paper from the tray. Message printer out of paper.
Have you checked for any paper jams?
If there are no paper jams, remove the loaded paper and separate the pages by "fanning" the paper
If all the above do not work, use a bit of rubbing alcohol on an earbud and clean the pickup points on the paper roller.
Mar 04, 2015 | HP Officejet 6500A Plus Wireless...
During multiple feeds, the 1st copy is okay, but on the next succeding copies, top margins spacing varies that will cause the bottom copies to be cut
Meikriezl Ulit:
Remove the paper tray and use a "Q-Tip" dipped in alcohol to clean the paper pickup roller and the double-feed prevention pad (below the paper pickup roller.
Feb 24, 2013 | Toshiba Office Equipment & Supplies
How do I get my HP2575 printer to pick up the paper in the paper tray?
Hi jtheiss,
When you send a print or copy to the printer does the pickup tires attempt to pickup the paper?
Apr 12, 2012 | HP Photosmart 2575 All-In-One InkJet...
Paper feeding problem with MFC-8670
Try REMOVING the white caked up paper dust from the pickup roller located at the front of the paper tray. Next, clean the pickup roller with either 409 or Fantastic all purpose holdhold cleaner using a Q-Tip or a rag.
May 10, 2010 | Brother MFC-8460N Laser Printer
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
Paper Jams on letter tray
The paper pickup rollers are dirty and needs cleaning. take out trays and give it a wipe with damp cloth, if problem remains than need to replace the rollers
Oct 12, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageCLASS D780 All-In-One Laser Printer Logo
69 people viewed this question
old marine
old marine
