Question about RCA F19262 19" TV
The TV picture is not focused.Is there a way to focus it?
  • 157 Answers
Yes,remove the back of unit.you will see a red wire leading to the picture tube.Follow that wire down to the board.You will see 2 controls on the transformer.top one is focas,bottom one is screen.Turn focas control until picture is clear.
Posted on Oct 08, 2009
Sharp TV slightly out of focus
so not focus on out side please focus on write side http://specialneedsplanning.net/
Mar 18, 2013 | Televison & Video
Pix is dim and too big for screen
Hello
Your TVs focus voltage has some trouble. You gets an out of focus piture now. There may be two reasons for this fault. The first one is, the focus pack trouble. The second one is picture tube base socket trouble. Both are repairable.
Focus pack is integrated with Line Output Transformer [LOT], and picture tube base socket is soldered directly to picture tube base card. You just open the TV and check whether there is any "Shhhh" sound comes from the neck side of the picture tube while tv is working. If it is so, you will get a smell of Ozone gas also. If it is so, switch off the set and unplug it from mains socket, pull out picture tube base card from the picture tube neck. Be gentle, and not make any shakes while pulling it out. The neck part of the picture tube is very thin relative to its other portions of the picture tube, and have a chance to break. So be carefull when you pull it out. You can see the base socket soldered directly to it. There will be two wires also, for some sets only one, attached to it. Normally the red wire going to a slot in the socket is focus wire, through which focus voltage reaches to the relative pin of the picture tube. Just detach the wire out from the socket, desolder it out and go for a similar type, and pin confuguration. Replacing it will solve your problem. After replacing the picture tube socket, a slight focus adjustment may be needed. Sometimes may not. The focus voltage can be adjusted. Its adjustment control is located on the above said [LOT]. There will be two adjustment controls, marked Focus and Screen. Out of which the upper one is for focus adjustment, and the lower one is for screen adjustment as its markings states. You just adjust the focus control very little, while watching the picture on your tv screen. Take menu display for reference, rather than moving pictures for focus adjustment, so that you will get a stationary image for reference.
The second stated trouble is related to the screen-focus pack integrated with the [LOT] itself. If it has got damaged, there is no other way than replacing the [LOT]. If so desolder it out from the circuit board, after detaching the anode cap from the top of the picture tube,and focus and screen wires. Before detaching the anode cap, care must be taken, as there may be some extra high tension voltage charge on the final anode of the picture tube, which is dangerous. You must discharge it before unpluging it, otherwise you may get electric shock from it, even after the Tv is switched off and unpluged from the wall socket. The charge may retain there for hours. So be careful.
If you have any more doubts, inform me through Fixya. Ok.
Nov 05, 2010 | Sanyo DS24424 24" TV
Is there a focus for my F19251GY TV
Hello
Yes, of course there it is in every TVs. The focus adjustment in TVs determine the clarity of the display. It is a service adjustement and if you want to adjust it you should open your TV. It can be located at the Line Output Transformer [LOT], and integrated to it.
There will be two adjustable controls can be seen on the LOT. Out of which one is Focus control, and other is Screen control. Both are marked. Normally Focus control is placed on the top side and Screen control to bottom. Both controls are interactive, that is adjusting one will effect the other a little.
If your TV is out of focus, you just open its back cover and locate the said control. It will be usually marked as focus. Adjust a little while looking at picture to get a well defined focus. For this adjustment, take its menu display as reference rather than a moving object. Adjust it to get a well defined display. Place a mirror in front of your TV, so that you can see the image on it from back side.
A defective CRT [picture tube base] "socket" may also be the cause out of focus picture. It can be located on the base card of your TV, and can be detached from it desodered. If the above said adjustments did not give any results, the CRT Base may be defective. If base socket is defective, you can hear a very slght "shhhh" noice from it as you advance the focus control. Try to find out and rectify the problem. Ok
Oct 26, 2010 | RCA F19251GY 19" TV
I think that it is the green because i did what you said and it is still there. there is a feature on my tv called magic focus it brings up the colors and the blue and the red are very focused but the...
This tv is a DLP projection tv right?Magic focus button push don't solved the focus picture problems,have colors shadows or 3D pictures problems?The tv have a problems known as a convergence problems,it dead.The tv convergence board.Must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved the tv picture convergence problems.The shop,will cost u $300-$350 for parts and labors.
Oct 02, 2010 | Televison & Video
The tv will not automatically come into focus
U have pictures out of focus?Like pictures colors seperates in lines?Ur tv convergence are dead.U know how solders?Must replaced 2 STK convergnece ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
Picture out of focus. type or subtitles are fuzzy Have tried all picture adjustments in "menu"
As the CRT (picture tube) weakens the electron beam will loose some of its intensity. This will cause the beam to become a little wider, and thus the scanned picture will look softer or out of focus. Most of the time, the corners, top, and bottom tend to start getting worse than the center.
Sometimes the focus bias can be cheated a little. Some models of TV sets have a focus pot on the CRT circuit board, or on the high voltage multiplier. This control works in a high voltage area. I suggest you get experienced assistance for this. If you take the TV set over to a local TV shop or find an experienced tech, he could try to adjust the focus for you.
Considering the age and type of set you have, you would be better off getting a new up to date TV set.
Jerry G.
Sep 26, 2009 | Samsung TXJ2554 TV
Picture goes out of focus
besides using a bigger hammer you need to adjust the focus controls under the speaker cover from the front
Feb 25, 2009 | Sony KP-57WS500 57" Rear Projection...
Focus the picture on a Model 27GT619 Television
The focus control is on the flyback transformer (Usuallly black or brown with three wires coming out of it. The bigger wire goes to the pix tube with a rubber cap at the end.) The focus control is on the side. There are two. The top is focus. Good Luck!
Jan 13, 2009 | GE 27GT619 27" TV
Focus
Focus control is on the Flyback there is 2 adjustments one is screen drive other is focus turn it untill you have clear picture.
Sep 03, 2008 | RCA F32450 32" TV
RCA F19262 19" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
