Question about Konica Minolta Office Equipment & Supplies
Form my Konica 2223, I can only set fixed magnification to A3 to A4R / A5 to A5R and A4 to A3 / A5 to A4 and other fixed magnification positions (such as B4 to A4R, A4 to B4 ect.) can?t select. Please help me.
  • Konica Minolta Master
  • 1,297 Answers
The zoom magnification is fixed to only one work.To change the work mission lost zoom fixed.For only work is fixed the zoom ratio.
Posted on Oct 08, 2009
Konica Minolta says that A4 portrait is A5 but when it is landscape it is A4.
what model machine??? are the draws properly set for the correct paper, empty all draws send the print job let the screen tell you what to do next.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 20, 2016 | Konica Minolta Office Equipment & Supplies
HOW TO SET OVERLAY OPTION IN IR 3300
ID CARD OVERLAY SETTING IN CANON IR 3300
1 go on speacial features --- imeg combination --- select A5R --- 2on1--select paper tray A4 --- ok--done.
(dont do press reset otherwise setting will erase).
after that comes again in speacial features ---mode memory ---select M1 ---- go in store /erase ---store ----next ----its show setting A5 2 on1 select yes ---ok ---done. reset (this setting will store in your speacial features if u wants to use it u can use special features ---mode memory select M1ok).
if u wants that this funection show on main screen
then press * additional funection key -----standard key 1 setting --
mode memory ---m1 ok ---done ---done .
u can replace the name of m1 to overlay but i think no need for it.
do it and reply here.
Mar 14, 2015 | Canon Ir 3300 Black & White Copier
My printer ir 2022i has a problem that when copying some documents, image is printed in different position from the original placed. I place a document in the copying board in A4R position and choose the...
The only thing I can suggest is to run a printer calibration. This will be in the set up menu. If there is not an option for this in the menu reinstall the software. At the end it should ask you to print a test page at which time it will align itself. You know, first I would check the print menu on yor printer to make sure you did no set it to A4 as the default.
Jan 07, 2013 | Canon iR 2022 Printer
I need to copy from A3 to A4R and cannot find how to change the paper to A4R
Right click on printer. Click on Printing preferences. Under quick setup tab, on the printer paper size box click the drop down arrow, choose A4.
May 16, 2011 | Computers & Internet
How to scan in two faces in one side for exmaple ID in photocopy scan and printer " canon IR3045N"
select special function on screen>image combination>2 on 1>original size a5R(if u r copying on a4R paper then original size a5) then scan both faces to be printed and >done
Feb 03, 2011 | Canon Office Equipment & Supplies
Printing on custom paper sizes I can not set my a3 printer to print any longer than 42cm x 29.7cm A3, It should be able to print 29.7x 84cm half of a2
The following are the max printable areas for the Canon i9950.
A3+, A3, Ledger, B4, A4, B5, A5, 5" x 7", 4" x 6" Size
Printable Area (width x height)
A3+ (13" x 19")
322.2 x 475.0 mm / 12.7 x 18.7 in
A3
290.2 x 412.0 mm / 11.4 x 16.2 in
Ledger (11" x 17")
272.6 x 423.8 mm / 10.7 x 16.7 in
B4
250.2 x 356.0 mm / 9.9 x 14.0 in
A4
203.2 x 289.0 mm / 8.0 x 11.4 in
B5
175.2 x 249.0 mm / 6.9 x 9.8 in
A5
141.2 x 202.0 mm / 5.6 x 7.9 in
5" x 7" / 127.0 x 177.8 mm
120.2 x 169.8 mm / 4.7 x 6.7 in
4" x 6" / 101.6 x 152.4 mm
94.8 x 144.4 mm / 3.7 x 5.7 in
Borderless printing will allow you to print up to the full size of the paper but no larger than 297 x 420mm for A3 and 330 x 482 mm for A3+.
It is not possible to print on A2 paper.
Oct 13, 2009 | Canon i9950 InkJet Printer
School Truancy Report Formula
For the same exemple you can try this:
=COUNTIF(A1:A4,"=George Washington School")
Apr 03, 2009 | Microsoft Excel for PC
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
89 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
