Question about Whirlpool Dryers
Whirlpool dryer stopped in mid cycle, didn't smell anything, it just stopped. opened and closed the door and tried the start button again and it still wouldn't turn on
  • Whirlpool Master
  • 7,482 Answers
Sounds like your problem may be a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the problem is not a broken belt then you have to motor exposed to do further testing, if the motor is ok, then check the start switch and the timer switch
Good luck,
I hope this helps
Posted on Oct 08, 2009
Press start button and dryer will start and stop , if you press start button again nothing happens , if you unplug dryer and plug back in it will try to start again and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Dec 09, 2009 | Maytag Dryers
220 dryer intermittently tech says dryer ok electritien says wiring 2 dryer ok and breaker ok
This sounds as if the door switch is weak or the actuator is damaged and turning off the dryer before the cycle is complete. Make sure your dryer door closes and latches properly. If it quits mid cycle again press on the door and then press start...DO NOT open the door until you try this. If pressing on the door and pushing start gets a cycle start then I suspect you have a door switch problem. However,,,,, a dirty / cl;ogged vent or an air blockage some where in the vent / dryer air flow ducting can give you intermittent operation also. Make sure you check the outside flapper valve where the vent exits outside the house also. Hope this helps. Cheers!
Oct 15, 2009 | Whirlpool LER5636P Electric Dryer
Stuck Mid-Cycle, Wet Clothes!!
unplug the machine for 15 minutes then try again
Jun 09, 2009 | Whirlpool GHW9150 Duet Washer
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 | Dryers
Whirlpool gas dryer stops in mid cycle and then starts up again
make sure of mode# make inside door and I will help you. also how old is your drier?
Feb 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Whirlpool Model LG7681ZSN1
check the door switch if it is working then a broken belt can cause this problem let me know how you make out
Sep 13, 2007 | Whirlpool LGB6000KQ Gas Dryer
Dryers Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
