Question about Sun Ultra Enterprise 450 Server
Cannot see mixed capacity hdd in Sun E-450 - Sun Ultra Enterprise 450 Server
  • abdul latheef May 11, 2010
    dear,
    Can you give me below command output
    devfsadm -Cv
    echo|format
    Problem Solver:
  • 4 Answers
Good day,
Please advise if the problem still exists.
Posted on Sep 24, 2010
How many gallons of antifreeze will it take ?
Anti freeze is mixed on a 50/50 basis. The coolant capacity varies so check the hand book for capacities and mix the anti freeze to water before adding to radiator. Drain radiator first so as not to mix different anti freeze products.
Nov 09, 2013 | 2005 Toyota Matrix
Sun E450 Will Not Power Up
dear sir plz sot out my problem
problem is sun ultra e450 server dc fale error how to solve
Jan 06, 2012 | Sun Ultra Enterprise 450 Server
I am using a compaq presario SR 1435IL. I want to know whether i can use two internal hard disks and also upto what capacity is it supported I already have a 320 GB western digital hard disk. Does it...
hi, i believed there is no possible way of putting 2 internal HDD in 1 laptop, seems the area of the existing HDD inside is already limited and also crowded of some other parts...and its not designed for 2 HDD either. the best way for me to advice is upgrade the existing HDD to higher capacity from the existing " GB " to " T " or add up a big capacity 2.5 " pocket size external HDD.
Aug 26, 2011 | HP Compaq Motherboard
I replaced the original burnt motherboard with gigabyte g31m-es2l an my sistem does not see the full capacity of the 2 HDD of 500 GB each.Instead reconizes only 129 GB of each HDD. CPU is quad 2.4...
you must update your bios so that it will accept the large capacity drives
otherwise, it only let you have about 60 % of the total, and the rest winds up going to waste because it's not getting used
Dec 16, 2010 | Gigabyte GA-G31M-ES2L Motherboard
How much engine oil does my 2005 crf 450 R need when changing oil and filter?
Engine oil:
Fill the crankcase with the recommended oil. Capacity: 0.73 US qt (0.69L) at oil and filter change Tansmision oil: Fill the crankcase with recommended oil. Capacity: 0.62 US qt (0.59L) at oil change.
Dec 07, 2010 | 2005 Honda CRF 450 R
What size of sata hdd i can connect to mb mercury pi945gcm????
you can connect any size SATA HDD to your system. Depending upon the OS and drivers you may have to create logical drives to handle the capacity. If you decide on a large capacity HDD such as a 1TB drive, backup becomes an issue. You may want to keep your working drives to a manageable size and attach a backup hight capacity drive for backup.
If you have any questions, please let me know.
Please rate this solution. Thanks.
Aug 30, 2010 | Mercury P4VM800M7 Motherboard
I got an error 100 & 106 on my toshiba e-studio 450 I was told that I need to change the hdd. The old hdd seems to work fine on my computer though! can I use any regular hdd or should I use the exact...
You do not have to worry about the capacity of the hard drive . Just be sure you get the same interface, ATA or SATA, as long as the capacity is the same or greater. Format the drive through the copier's menus.
Jun 19, 2010 | Toshiba E-STUDIO 450 Copier
Maximum HDD capacity of an ACER Travelmate 212 TX
Yes you can install a 20 Gb hard drive but I doubt you can buy a new one with that small capacity. The smallest capacity hard drives are approx. 80 to 100 Gb or greater.
You most likely can buy a 2nd hand drive but you don't know its quality, it may have had a hard working life and you don't know how long it will last, but then, if is very cheap that may not be a problem.
Mar 31, 2009 | Acer Computers & Internet
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Jul 21, 2008 | Heating & Cooling
Sun Ultra Enterprise 450 Server Logo
207 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
