Question about Durabrand HT-3915 System
Fuse Hello I need a Fuse for this system and am having a hard time finding one. Where can I get a fuse?
    Problem Solver:
  • 6 Answers
Radio Shack or an AutoParts store like Napa.
Make sure the replacement has the exact same rating as the original.
Posted on Feb 16, 2008
I have a dashcam that I want to hard wire into my fuse box. I need the schematic for fuse box and advice on how to remove the fuse box cover, please.
Your going tho have a tough time getting anything online about your fuse box on a newer T-Bird. You can check out some chat rooms, your best bet is finding a T-Bird club in your area. Some of the info is pretty hard to come by.
Apr 09, 2015 | 2004 Ford Thunderbird
Hello , I have a new Tiguan trend and fun 2.0 and my dash light and radio won't work.
Check the manual and find the fuse box or boxes. find the dash lite fuse, it may say " interior illumination" If it is good check also the radio fuse.
If the fuses are good, you have to visit a wv dealer for detailed fault finding.
If the car still have warranty, don`t mess with the electrical system.
The car also have can bus electrical system, and it can go wrong when you try to fault find your self.
The fault could be the light switch, fuses, the radio.
Here is a fuse list for a golf:
Check the Fog light relay, instrument panel light dimmer switch fuse.
Good luck
Jan 08, 2013 | RupseTM For VW: New BORA / PASSAT CC /...
Hello i have a 2004 expedition , and i have been having issues with my battery draining. about a month and a half ago i went away vacation , came home to start my truck only to relize my battery was dead....
Your solution is a little hard to find too bad they told you to change the alternator. It is a simple fuse you need to change that is blown. on the expetion sometimes there are two one in the fuse box and one under a black cover follow the alternator small wires it should point to the direction of the small i believe 7.5 amp fuse. it was hard to find and i do this for a living. good searching.
Apr 20, 2011 | 2004 Ford Expedition
Having issues with car computer having to be reset it's happen 3 times & I was told it may be fuseable link or relay fuse.will not start or take a jump.something to do with electrical system
fuse able links are hard to find if you dont have a wiring diagram to go by but relays and fuses are easy i would check for any bad fuses and bad relays its not uncommon for most cars to have a breaker style fuse/relay and they do go bad. if your having to have the computer reset i would look into having it tested also.
Dec 24, 2010 | 2000 Saturn L-Series
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
I need help finding the correct fuse for the power windows. all of the power windows stopped working at the same time, so i figured it was a fuse problem. i know where the fuse box is, but which fuse is...
this system doesnt use fuses it uses ciruit breaker for the windows,these hardly ever go bad, what does go is the wiring, remove the rubber boot in the middle of door hinges, there il bet you will find broken wires, take a look.let me know.
Mar 11, 2010 | 1995 Jeep Grand Cherokee
First the dashboard and tail lights quit working. I replaced the fuse and it blew the same day. I have since replaced the same fuse 2 more times. Also now when I press on the breaks the turn signal lights...
Hello. You have a short in your electrical system. These shorts can be difficult to find unless you have the proper diagnostic equipment. I recommend that you locate an autoelectric shop in the area and take it to them to find the short and repair it.
Nov 28, 2009 | 1998 Kia Sportage
Windsheild wiper not working found fuse box but it does'nt say what fuse is to windshield wiper please send me a diagram of the fuse box for a 93 jeep grand cherokee laredo 6 cilinder
Hello www_ericvane,
Pull the fuses one at a time and check them with a meter. If you do not have a meter, physically examine the fuse for a burned link.
Here is what a burned fuse (left) and a good fuse (right) look like.
Some auto manufacturers have some of their fuses in the engine compartment instead of in the fusebox under the dash. If you do not find any burned out fuses in the under dash fuse box and can't locate any others in the engine compartment, you will need to check your owners manual or go online to find the wiper fuse location.
Of course, you may find that it isn't a fuse at all, but the wiper motor, the parking relay, or some other electrical component.
Hope this helps.
Jul 31, 2009 | Metra Ford/Chry/Jeep 1974 99
I have a 25 wat fuse in my power wire connected to my amp and i keep blowing it. should i put a bigger fuse in it?
Hello grabert205,
You do not say if the fuse blows immediately upon powering up or while the amplifier is operating. If it blows immediately, I'd check the power and ground.
If it is blowing the fuse while operating, I'd try a 30A and see if it holds. At maximum output of 100 watts times 4, the amplifier needs about 31 amps of current at 12.8V. So driving it hard could certainly blow a 25A fuse.
Hope this helps.
Jun 13, 2009 | DHD LCD-9444 Car Audio Amplifier
TV Fuse
Most of the time the manuafactirers put the fuse around where the line cord comes into the back of the TV set. are you sure the fuse is bad? Are you thinking the fuse is bad because the TV set will not come on?
Mar 26, 2007 | Durabrand DWT2405 24" TV
Durabrand HT-3915 System Logo
78 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
