Philips 60pp9200d/37 no video or sound. Power light flashes error 61. There is a spark gap component on the LSB board which arcs when the set is first plugged in, before the error is flashed. Picture tubes filaments also come on momentarily. No other physical signs of damaged. Installed a new LSB and MSB board with no change.
  • 11,896 Answers
I do recommend checking the power coming out of the power supply to make sure it is not to high. It is common for these units to have faulty internal capacitors in the power supply. It may be shorting out other components. You can buy a capacitor tester or use an ohmmeter.
Posted on Oct 08, 2009
Philips Projection 60PP90200D/37 NO PIC NO SND 6X/1QF
I had the same problem. It is error code 61 which is a power supply fault. Had a bad LSB board (pn: 313926719011 from MCM Electronics) which blew out on of my CRT. If you have any observed arcing in your CRT's, they are bad and will need to be replaced. I went to Ebay and found a used compatible Philips brand to replaced the CRT. Do not isolate the high voltage lines of the bad CRT to troubleshoot with a bad LSB. The LSB will short out another CRT (it did on mine). I bought the service manual an learned the set does not tolerant of power line surges. If you fix it, invest is a good surge protector.
Aug 27, 2009 | Philips 60PP9200D Television
Philips 60PP9200D/37 60-Inch Widescreen Rear Projection HDTV has sound but no picture
You will need to purchase the small signal board......they are kind of difficult to remove and replace. They sometimes look like a small aluminum sandwich box or they look like a video card out of a computer. Read the instructions to replace and reprogram this. Look up at the Philips Partstore.com. Type in model # and see small signal board......These canbe pricey $$$$$$$$
Aug 04, 2009 | Televison & Video
MY 60 INCH PHILLIPS 60PP9200D/37 WILL NO POWER
If the front power light does not come on check the fuse in the back of the Tv.
Jul 18, 2009 | Philips 60PP9200D Television
Hi thanks for replying
The clicks you are referring to sound like High Voltage Leaks or Arcing. While it is clicking check for sparks around the high voltage transformer only with your eyes from a distance. If you see sparks shut it off immediately.
Dec 29, 2008 | Philips 42PFP5332D 42 in. Plasma...
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 60pp9200d
6 blinks means general I2C error and 8 blinks means 3D comb filter I2C error. you will need a new signal board for your set, or possibly have yours remanufactured which may be considerably cheaper than a new board. If you need more info please repond to this same post and let me know.
Aug 14, 2008 | Philips 60PP9200D Television
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
