Question about Canon PIXMA MX310 All-In-One Printer
My fax is not working. It is possible it is not hooked up correctly
  • 56 Answers
Hi, you must first chech the line socket it you have a line.
the check if you are using the right cannon cable supplied.
check to see if you you have connected to the LINE socket.
lastly if you press the hook button you shoud hear a tone comming from the speaker in your machine, make sure it is at maximum volume.
Good luck
Posted on Oct 11, 2009
Send fax
With a single phone line only the phone or fax can work at one time but not both together.
May 02, 2013 | Canon Pixma MX360 Printer
My fax machine was working great up until this morning. I am able to send faxes but not receive them. The machine is hooked up to the phone jack and shares the line with our credit card machine. It is not...
It's entirely possible that your fax machine will just miraculously start working again. If it was hooked up to your computer you'd possibly be getting an error message, which when interpreted by its code number, would tell you it's not receiving the phone signals correctly for a period of time but soon will.
Hope I'm right,
Regards,
selk
Oct 18, 2010 | HP Officejet 6310 All-In-One InkJet...
Line in use
Hi there, the fax machine on your all-in-one printer is really handy when it works properly. Getting your fax capability back requires a troubleshootingmag-glass_10x10.gif process that moves through the possible causes of a problem and arrives at a solution. Follow these steps to troubleshoot the fax machine on an all-in-one printer.
  • Plug the power cords in, push the power buttons on and get everything up and running. Sounds simple, but lack of power is the culprit quite often.
  • Step 2.Check for a phone connection in the correct input jack. Some printers with fax capability have more than one phone jack so you can hook up an answering machine or another phone "downstream" from the printer. Consult your instruction manual to determine the right connection for your printer.
  • Step 3.Swap out the all-in-one printer for a working phone to find out if the problem is in the phone line coming from the wall. Once you hook up the phone, you should get a dial tone if the line is working. Remember to reconnect the all-in-one printer after you're done.
  • Jul 31, 2010 | Canon L220 Plain Paper Laser Fax
    Can't receive faxes
    Hello. Make sure you're plugging the printer to the correct phone jack in the wall. If you're using a splitter, bypass it. Check the settings in the printer. Make sure you assigned the correct Fax number in it and place your Fax name as well. If you're sharing your home phone line with the fax and you have an answering machine, set it to answer first and the Lexmark fax later with a minimum of 2-ring gap. If you have a voicemail, turn it off since it will a conflict with the fax or avail a distinctive ring feature from your phone company so it can work with the fax. Hope this helps.
    Mar 23, 2010 | Lexmark X6170 All-In-One InkJet Printer
    What does communication error 20 06 mean on my brother intellifax 4750e? We have been having problems faxing out and customers have called with trouble faxing in. Yet, we have received faxes prior to them...
    CRC error in answerback. It means the error correction digits didn't match the data that was sent. I've seen a few cases where this was bad phone line conditions - once I could see the phone lines scraping against the gutters in the storm outside the window - but usually it's a flaky Main Board in the fax.
    Unplugging all the cables on the board and plugging them back in might clean a bad connection, but we're seldom that lucky.
    Jan 27, 2010 | Brother IntelliFAX 4100 Laser Fax
    Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
    I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
    Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
    My Panasonic FX-FL541 fax macnine is not working. The led display says 'ext. in use' and it won't let me do anything. The power is on and the phone jack is hooked up correctly toa fax line. HELP!
    You may wanted to double check if the fax is connected to the phone jack and the cable modem. If it is, and it still doesn't fax... try pressing any key on the fax. Let me know if it works?
    If it doesn't, here's a link to the dept...
    http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+Fax+Machines-UCM_PRD_CNT_002049
    Jun 01, 2008 | Office Equipment & Supplies
    Pixma mx700 fax will not work when hooked up to answering machine
    check for dial tone on your fax,and check to see if your fax telephone line is plugged into the "L" and not telephone. the L or line is the correct way. alsois it when you are trying to send or recieve.
    Thank You,
    Mikey
    Apr 04, 2008 | Office Equipment & Supplies
    Brother mcf-440cn
    Jacki
     Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
    If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
    Oct 21, 2007 | Office Equipment & Supplies
    Canon PIXMA MX310 All-In-One Printer Logo
    54 people viewed this question
    old marine
    old marine
