Question about Landice L7 LTd Pro Sports Trainer Treadmill
My L7 has been running just fine. Today it would stop durning the program (with speed about 2.5) and then start back in a few seconds. It slows down like it is getting stuck or bogged down but only for a few seconds (max5-10 sec)then goes back up to the set speed. I set it a 3mph and let it run and this did not occur, but at 2,5mph and 2mph this happens? Otherwise it is quiet and seems to be normal.
  • vintageso357 Oct 09, 2009
    I cleaned and lubed the track and adjusted the belt. It passed the slip test , however this morning when I ran the program again (30min P1 max speed 3.7mph) it stopped 3 times in the first 5 min starting almost immidiately, 5 times in the next 5 min and then it did not stop again until 23 min into the program and again at 27 min into the program, again starting back almost immidiately?
  • 855 Answers
Not sure how long or often this is used, but you may just have to do a maintance on it. In your manual it will show you but all it sounds like is the tracks need cleaned and oiled. The slowing down will show up at slower speeds first due to the fact that the motor is not turning as fast and will feel the drag of dry or dirty tracks. When you are going faster this will not be noticed as much since the motor is spinning faster it will over come slight resistance. So try cleaning and oiling the tracks as per your manual and your problems should be solved. You may also have to adjust the tension on the belt
Posted on Oct 08, 2009
  • Ronald Park
    Ronald Park Oct 09, 2009
    Sounds like you have done everything right so far. The next thing would be check the electrical connections are all still good and tight. If they are loose this could cause the problem. But it sounds more like something in the motor itself, that is causing it to need to warm up before operating properly. This could be the brushes or the armature. If it is under warranty take it in. If not call around your area for a shop that repairs that type of equipment. This is something that can be repaired and you do not have to purchase a new machine.Wish you luck and leave a comment if any other questions.
My treadmill slows down lately on its own. What could it be?
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 09, 2017 | Weslo Exercise & Fitness
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
Engine cuts out when slowing down
Start off by cleaning carbs,sounds like idle jets are blocked
Feb 27, 2014 | Boating
Blower motor
may be motor on way out ,,,,, the resistor for the system usually allows full blower power when set to top speed,,,,
Nov 22, 2013 | 2005 Ford Focus
Kymco **** 125 (1998) Engine lost power then cut out, now won't start
Is this a gasoline powered motorcycle/scooter? If so and if you got off in dirt, the carburator may have dirt in it. Drain the gasoline, clean the jets in the carburator and try again. If its electric, sorry, can't help!
Aug 15, 2012 | Cars & Trucks
Maytag Performa pav2300aww stops and starts
If it's stopping during a wash cycle, suspect the heater elemant not heating up and moving the controller on. See if it runs fine during a spin/drain cycle. If it is very slow on all programs, try the noise filter capacitor before condemning the controller.
May 18, 2012 | Washing Machines
1996 Bonneville Pontiac kills, hesitates, lurches
ignition modules can cause problems like this also airflow meters and faulty fuel pumps
Apr 14, 2010 | 1996 Pontiac Bonneville SE CA Value
COMPUTER STARTS AND RUNS SLOW.. CHANGES PROGRAM VERY SLOW.
some tips:
1. Kill unnecessary programs, you can do it from task manager.
2. some program starts at startup of PC, they make PC slow, go to start>run, type msconfig and say ok, go to startup tab and the disable the programs which you do not want to start up during PC start up.
3. downloan CCCleaner and run it.
4. Keep C drive clean as possible, move as much items to other drive, less space on c drive can slow down you PC.
5. Many files placed on desktop can make it slow.
6. If you have low memory on your PC then you have to increase it.
7. Virus or Spyware can make pc slow do thorough scanning of your PC.
8. I suggest you to uninstall any programs which are not necessary.
all the best.
2667305
Mar 13, 2009 | Dell Microsoft Windows XP Home Edition
My volvo 96 850
all you need to do is clean the throttle body using gumout throttle body cleaner which should only cost about $6 givr or take
Mar 10, 2009 | 1994 Volvo 850
Landice L7 LTd Pro Sports Trainer Treadmill Logo
97 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Dave
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
