Question about Craftsman 24 Hp 48" Deck Yard Tractor
Deisel was accidently pored in my lawn tractors. i have drained the tank and lines the best i could but with new gas it still will not crank.
  • 403 Answers
You should be fine, check your fuel filter and prime the motor before you start it. Might get a little smoke when you first start it but should be fine. Hope this helps. Let me know if I can help with anything else.
JimmyC
Posted on Oct 08, 2009
    President:
  • 986 Answers
Drain your carb ,And give it some starting fluid and start let it run untill it all clears out,I hope this helps you
John deere L100 cranked over...wouldn't start...out of gas....added gas, now wont crank over at all
Thou has drained the battery with all your cranking. Recharge unit and now check for spark since you have resolved the fuel delivery issue.
Mar 14, 2016 | John Deere Garden
My Craftsman lawn tractor will run for a while and then stop then sometimes after sitting for a while will run again. What should I check? I added fuel additive to gas just incase the fuel was bad.
Drain the fuel tank. Dispose of the gasoline responsibly.
Replace the fuel line between the tank and the carburetor.
Put fresh gas in the tank. See how long it runs.
While you're at it, change the oil and remove any debris from
the cooling fins on the engine. It may be overheating.
If it still doesn't run, you probably failed to replace the fuel line.
Trust me, this is part of good maintenance for these machines.
Sep 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas tank
Un hook the gas line,.drain all gas out.Get a rag,stuff it in gas tank.Get a 1/2 inch dowl.About 7 inches long.Stir the rag inside gas tank.Take rag out,put new rag in tank Swish around inside tank.Get as much as you can out of tank.when you get it Quite clean,add /spray Carb cleaner into the tank.And some gas,drain again until its clean.Only enough gas to swish around.You can see inside tank with a mirror.
Jul 24, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
I accidently put diesel in my John Deere riding lawn mower. How do I safely drain the tank. Or do I need to take the tank completely off? If so I need directions.
If you did not try to start it, you will need to siphon, pump or **** out the fuel tank. The last J.D. that I emptied the tank in I used a turkey baster to draw out the bad fuel. I guess you use what you got. Hopefully your fuel is pumped to the engine and the fuel line goes into the tank from the top. If so all you have to do is empty and replace with gas. If the fuel line drains the tank from the bottom and/or you tried to start it with diesel in it you will need to (after emptying the tank) remove the fuel line from the carb. and direct it to a container, remove the bowl nut of the carb. to drain carb. be ready to clean up a little spilt fuel catch if you can or have rags under and ready. Turn the ignition key for engine to turn over to operate the fuel pump and clear the line. Put a little gas in tank and flush fuel line by using fuel pump to clear. Change fuel filter and put everything back together. Remove and clean/replace spark plug. Test it. Inspect spark plug again if necessary.
Jul 07, 2011 | Garden
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
How to drain the old gas from my 20.0 HP, 42 in. lawn tractor. Thank you, Nancy
Remove the fuel line from the engine and drain the old fuel into a container. Follow the fuel line from the fuel tank to the engine. Anywhere along that line where you can disconnect it do so. The fuel filter is a good place to disconnect it and then you can replace the fuel filter when you connect it back up.
Apr 23, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman riduing tractor turns over but won't
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
May 09, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Murray 36" cut riding lawn mower, with a 11 hp Briggs engine. the problem, I am having, is it is getting gas mixed in with the oil. when I drained the old oil, it had a strong gas odor. I...
You need to rebuild your carburetor and fuel pump.
Once done, change the oil again.
You might want to consider adding a fuel shutoff valve to your fuel line between the tank and filter. It is a great convenience if you do your own repair work.
May 05, 2009 | Briggs & Stratton Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
42 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
