Question about Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM PUMP REPAIR KIT
How to install motor housing bracket on a jacuzzi pool pump motor or does it matter what side is up or down there are ridges on one side do the ridges go on top or bottom
    President:
  • Jacuzzi Master
  • 1,378 Answers
The 'toothed' edge goes on top with the teeth facing towards the motor. You will also notice the small support arm in the plastic is narrower than in the other areas of the bracket. That lines up with the seal plates locating tabs so everything is then lined up correctly for the insertion into the housing.
Posted on Oct 08, 2009
Jacuzzi pool pump delivers no water
wow if it got that cold there id be winterizing with food grade antifreeze not just drainig it down, you could miss pockets of water here and there and produce a crack in housing someplace , as for trouble shooting a no flow situation try the ole standby method of methodical subsitution it's worked for 100 years , keep removing parts (start at suction line in pool) temporray out of system till flow starts then you know last part sub'd out was it!!!
Apr 23, 2014 | Jacuzzi Pool & Spa
My Jacuzzi pool pump Mod.# 7lrc-48-s1/b is leaking from between the head and the motor housing.
this indicates a "mechanical seal failure" this will require replacement of said seal or entire pump
Jun 30, 2013 | Jacuzzi Pool & Spa
Jacuzzi pool pump leaking
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
Aug 04, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
Pool pump running low psi
your pump should be just fine once the water starts flowing again. You may have run it too long without enough water to cool the seal.
If it is leaking water between the Jacuzzi Pump housing and the motor then you will need a new pump seal. Those are common pool parts.
Rod
US Parts Center
888-521-6183
Jun 09, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
I have the wires undone the locking ring is off nothing I can see that is holding the motor into the pump housing. Can not get the motor to come out of the Magnum Housing. What am I doing wrong or forgot....
There is nothing else you need to loosen; your pump is simply stuck. It is common for Jacuzzi pumps to be difficult to take apart. You need to keep working the motor side-to-side and up & down till it finally frees from the housing.
John
Jan 29, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I've got no water coming thru the side jets in my pool, even though water is pouring through the jacuzzi jets. The jacuzzi is all part of the pool.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Sep 27, 2010 | AO Smith 1 hp Swimming Pool - Jet / Well...
Pump housing is cracked and lealing. Is there any
the pump housing is available through your local pool dealer. It is broken down into 3 sections the pump, housing and Pod.
The Pool Tech
Jul 01, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Motor removal on a Jacuzzi magnum force pump.
The impeller is threaded onto the end of the motor shaft and the housing (pump body) is attached to the motor with the same bolts that hold the rear cover on the motor they run all the way through on most pumps.
May 27, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
I have a Jacuzzi Magnum force pump
Good luck...Jacuzzi went out of business. The best source I have had for their parts is CCO:
http://www.jbparts.com/jbc0001.html
Jun 01, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM PUMP REPAIR KIT Logo
90 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
