Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
Hi, the machine keeps filling itself with water even when switched off? I'm guessing this is the double valve but am not exactly an expert. Any help is greatly apreciated. Thanks
    Scholar:
  • 57 Answers
If your machine is off and even unplugged then it could only be the valve not shutting off. If your intake hose filter screens are bad or not there the valve can get a flake of rust or mineral deposit from your pipes lodged in it causing it not to shut completely. Unplug the machine from the wall and if it is still flowing then you know there is no electrical circuit failure causing it to stay open. I have on occasion removed the valve, back flushed it and carefully opened the valve manually with a soft tipped tool while rinsing it out with success. If you do remove the valve take note of the wire connections and make certain the washer is unplugged before attempting the repair.
Posted on Oct 08, 2009
Testimonial: "Thanks very much, i'll give this a whirl a let you know how i get on."
    President:
  • 1,304 Answers
Yes it is your mixing valve
more than likely the cold has stuck open but ive seen both over the years
try searching for the part on the hoover website
Testimonial: "Thanks mate."
Water level control switch not working. even i set water level to very low it just keeps filling and has overflowed. i am guessing that the switch needs to be replaced.
It depending on exactly what your seeing that will determine the problem.
Does your washer start agitating and keep filling?? if yes it does start agitating and the water continuies to fill try disconnectiing the power and if it keeps filling what would be wrong is that the water inlet valve is sticking open and it would need to replaced
If the washer continues to fill and does not start agaitating would be a defective water level switch as you suspect it may be.If ya disconnect the power and it STOPS filling replace the water level(pressure) switch.
GENE
Oct 02, 2011 | Kenmore 24032\24036 Top Load Washer
LG WM1814CW washer - doesn't fill with water. Hear a hum when it should be filling with water, but no water and no error codes. I am guessing Valves (F160 and F170). Any thoughts?
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 08, 2011 | LG WM1814CW Front Load Washer
If I choose to have the water full to either large or even a medium level. It keeps feeling up and won't turn off. keeps running water. Why?
If water won't shut off even if you unplug the washer, then the water valve is likely stuck and will need to be replaced. If the water shuts off when water level switch is on low, but overflows when set on medium or high, it is more often the water level switch itself. Before replacing, be sure the tube going to the side of the tub is clear and not kinked. Remove the tube from the switch and blow thru it, reattach and try filling again. If it works, you should be ok, if not then replace water level switch.
Jan 18, 2011 | Whirlpool Washing Machines
Water filling up when off
May be inlet valve be defective kindly replace the inlet valve even if you find that same problem exist the problem with the motherboard of the washing machine kindly give to expert to do the service
May 03, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
GE washer keeps filling with water.
It sounds like you have a bad fill valve assembly. Normally the valve opens and closes by an electrically activated solenoid which is usually controlled by a pressure switch. However...IF the diaphragm that closes on the valve is broken, has a hole in it, cannot close all the way due to an obstruction, or if your water pressure is too low, the valve will remain open and water will leak by. Since you didn't mention any problems with the hot water side of the valve, I would suspect that water pressure probably isn't a problem. Turn the water off and remove the hoses to the fill valve on the back of the washer. Inspect the cold water side for any obstructions and/or check for any damage to the valve itself. If you don't find anything obvious, replacing the fill valve will probably correct your problem. I hope this helps.
Sep 10, 2007 | GE WBSR3140DW Top Load Washer
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
118 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
