Question about Dell Inspiron 1525 Notebook
Does not display when power card plugged - Dell Inspiron 1525 Notebook
    Novelist:
  • 225 Answers
Power card or power cord? you might be referring to the ac adapter right? just download and flash the latest BIOS for your system.
Posted on Oct 09, 2009
Ive tried to install a new graphics card in my lenovo thinkcentre pc but nothing shows on the display
Make sure your power supply is big enough and you have plugged everything in. Some video cards require power directly from the power supply with a special 4 plug cable. You can get adapters if your power supply doesn't have the right plug.
Sep 19, 2012 | Lenovo ThinkCentre A30 PC Desktop
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
My card is the r6970-2pm2d2gd5, When plugged into the motherboard (MSI 870a - g54) and powered on, no video displays on the screen. When a separate card was tested, video worked perfectly normal. Also, the...
1. Just clarifying things what does this mean ""When a separate card was tested"" does you HD6970 on crossfire?. or just a single card and the separate card means spare card. Am I right?
2. From your statement ""the fan began to rotate at an incredible speed"" does the 2x 8pin power connector plugged? reference images below.
6/8 Pin power connector
3. The main reason fans speed up and no display, you did not plugged the 2x 8 Pin power. if your Power Supply do not have such cables you better purchase one having 2-4 PCIE 6/8 Pin if you have plans on doing a crossfire setup.
Hopefully this information helps.
Just leave a message for clarification.
Thank you for using FixYa.
Aug 03, 2011 | MSI R6970-2PM2D2GD5 RADEON HD 6970 2GB...
When i plug in my card and boot my pc, it makes a high pitch squeeling noise and ive added another power cable but it continues to make the noise, how do i remove the noise?
From my experiance it sounds like the power supply is still not providing enough amps for the card or that the power plug on the card may be bad and not allowing it to recieve the power it requires
Dec 29, 2010 | ASUS EAH5850 DIRECTCU2DI RADEON HD5850...
How to fix aopen F75PS Display Power Light Blinking, Display Won`t come on.
A blinking power light typically means there is no signal from the video card, so check the connections and try another monitor (or plug the monitor into another computer) first to see if the video card is perhaps the real culprit.
Mar 14, 2010 | Computers & Internet
Cannot display anything at minitor
Check the vga connection of your monitor from your motherboard, be sure that it is properly connected. Check also the power cords of your monitor, be sure that it is properly plug. If still no display, then we have to do the hard way. Open your computer casing where the motherboard lies in. Remove the memory card and clean the pins of it by using an eraser of a pencil. Remove also the expansion video card if you have. Reset the BIOS,(to do this refer to the motherboard manual). Plug in again all the remove items from your motherboard, memory card and video card). Close the casing and then power on. If still no display then take your computer in a computer repair center in your place.
Nov 03, 2009 | Acer (ACERMOTHERBOARD)
Hi,my motherboard in not booting after connecting new power supply,power supply is OK,motherboard lights are on.But when start button is pressed its not showing anything
Try this site //www.dealextreme.com/.Repair tools cheap !! You need PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Price: $2.57 free-shipping_small.gif PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card costs $2.57 and free shipping.Great company.need help majortom350@yahoo.com PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Aug 22, 2009 | Computers & Internet
IBM Lenovo doesnt start. Fans are ok Ram and Graphics card attached with the system is ok( I checkd with another system). The led on front , the keyboard leds and cd driv leds turns on as soon as I press...
Sounds like your graphics card and display are not properly communicating. If the card doesn't sent out a signal to the display, you will see nothing on the screen. Did you check the graphics card on another machine using the same display? If so, something different may be wrong. I am assuming your display is powered on and plugged in properly. If there is more than one video connector on the machine, you may have it plugged into the inactive video connector. If all of this checks out I suspect you have some hardware problem with the system unit.
Jul 03, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
No display
Try swaping your memory with a known good stick of ram.
Are you sure your monitor is good? Video cables?
Try changing (if pci) slots when installing video card.
Other than these 3 things the only pretty sure thing is; sorry, mother board or cpu.
Jul 01, 2008 | E-Machines eMachines Desktop PC
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
Dell Inspiron 1525 Notebook Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
