Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Disposal hums but doesn't rotate. I would like to know where the reset button is so I can see if that is the problem. I've tried turning the inside mechanism but it won't rotate...
  • 403 Answers
There are several things you can check. First make sure the unit is off and check for debris stuck inside the unit. On the bottom of your Disposal is a slot for an allen wrench also most have a reset button here also. First take the allen wrench and turn the unit around several time manually before you do anything else. Now run some water down the unit and see if it will turn on. If it doe not try the allen wrench one more time and do the same as above. Now try the reset button. If this works great because the next step requires you to take the unit off. Let me know if this works before we go to the next step. Hope this helps.
JimmyC
Posted on Oct 08, 2009
    Problem Solver:
Usually there is a hex wrench that came with the disposal. Unplug or remove power to disposal.
First look inside to see if foreign object is in grinding chamber, if there is, insert hex wrench in bottom of disposal, rock back and forth to dislodge object and remove. Make sure motor shaft is free by rotating hex tool.
Usually the reset button is on bottom of unit , push in to reset circuit breaker and reconnect power and try to start.
If this doesn't fix problem you are probably looking to replace disposal.
Hope this helps with problem!!
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Kitchen aid kadette 250
with the power "off", check inside the unit to make sure nothing is jammed in there. assuming the interior is clear, try the reset button which is usually located on the bottom of the unit. may need to use a mirror and a flashlight to locate it. if the unit hums (indicating power is there) but it does not rotate/turn/work, use your "disposal key" or a hex wrench to turn it manually: usually inserts on the bottom-middle of the unit; turn it both ways to free it up.
Jul 05, 2013 | Garbage Disposals
My garbage disposal won't turn on, and i've felt down there and can't feel anything blocking it...what can i do now
Check circuit breaker.
Check red reset button on side of disposal and see if it's popped out. It's under sink, next to wire connection on disposal.
See if electric switch has gone bad. Listen if disposal makes humming sound. Humming means electric power is good.
Use vacuum cleaner hose instead of hand to check for stuff inside disposal
Use wood broomstick and see if cutter disk rotates freely.
If disk is stuck, wedge broomstick against side of sink opening until disk comes free, or use allan wrench on bottom of disposal.
If electric power to unit is good, and reset will not reset or reset is not tripped out, and if cutter disk rotates freely, then disposal has gone bad.
You can continue using sink as long as there is no leak that will damage cabinet underneath.
I wrote ex disposal replacement steps from my apartment maintenance days.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 15, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Stuck flywheel, disposal will not run, humminf noise Model: GFC525F GE
something is stuck in it, the humming is letting you know that its stuck. assuming you dont have a disposal turning wrench try this. unplug the unit under the sink. using an old wooden broom handle,, place it inside the disposal , and try and turn the unit. once you free it up, use a flashlight to look inside and remove whatever is jamming it up. once this is done, plug it back in and try it again. if the humming has stopped and it doesn't turn on. at the bottom of the unit is a reset switch. push it in, and try it again ( turn off the power as you rest it)
Apr 21, 2011 | Kitchen Appliances - Others
The motor tries to start with a low hum, but it will not power up. The blades turn easily and the reset button is not out.
If blades rotate freely, then there is no stoppage.
If motor hums, then circuit and switch are good.
If motor will not start, and reset is not tripped, then disposal has gone bad.
Motors slow down and overheat, and then they stop working.
Each time you hear motor humming instead of rotating, the motor is overheating.
All motors stop working some time.
There are no repair parts for disposals.
Drain is not clogged, so sink is usable until disposal is replaced.
I wrote EZ disposal-replacement steps from years when I worked apartment maintenance.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage dispoal not working. The blades spin freely inside, the reset button has been reset, when you switch it on the moter makes a faint humming sound, and the allen wrench will not rotate either way.
You need a new disposal.
Free-rotating blades show there is no obstruction.
Humming says you have power.
Frozen allen wrench says bearings are rusted.
Motor is now overheating each timer electricity is turned on, and motor will overheat and stop humming.
At least the drain is clean and water is not flooding under the sink, which means you can continue using sink until disposal is replaced.
I wrote tips for installing disposal from days when I worked apartment maintenance:
Feb 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal only hums. I can turn the blades inside so there is no food stuck. I know there is a reset button but cant locate it.
I had the same problem, it was just humming, then after a few second the on board circuit breaker would cut out. After a little while I could hit the reset button and it would just hum again.
It turns out that the base of the disposal was jammed. There are 2 blades on the top that should spin freely, but the base plate that the blades are attached to also spins. In fact, that's what the motor drives. The two blades on top are not powered, they just flip back and forth as the base spins. So get a broom handle or a strong wooden spoon, stick it down in there, and try to pry the base plate free so it spins. That should do it.
Oct 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water drains fine the unit runs but does not get rid of food
Be aware that your selected object you have a problem with is a hot water faucet made by insinkerator, not a disposer. I'm not sure what your problem is, but let's try to address the most common problems.
The disposer must be turned on and run to get rid of food. Does the motor come on when you turn it on? If it doesn't, does the disposer make a humming sound when you turn it on like it's jammed? If it makes no humming sound when you turn it on, first press the reset button on the bottom firmly. If the disposer then makes a humming sound, it's jammed. Read below. If the disposer still doesn't act like it has power when you turn it on, check the circuit breaker or fuse and try the reset button again. If none of this so far works and you still don't even hear it making the motor-stalled-buzzing-sound (open the cabinet door) then you should still check the disposer to see if it's jammed.
First, make sure you TURN OFF THE POWER to the disposer with the circuit breaker or fuse box. Now you need to check if the shaft rotates freely. On most disposers, there's a hole in the center of the bottom of the unit. You can insert a special disposer wrench or allen wrench into this hole and turn the shaft of the motor. It should rotate freely. You'll probably find the disposer wrench taped under the sink, or you can pick one up at a hardware store. If the disposer doesn't have this hole on the bottom, you need to go from the top. Remove the splash guard (black flappy thing) if it is removable on your model. Look inside with a flashlight for anything foreign that may be causing a jam like bottle caps. Place a broom handle against one of the lugs mounted on the wheel, and see if the wheel turns freely. If it doesn't, try to work it back and forth until it does. Then use tongs to remove the foreign object. After you clear a jam, it may be necessary to push the reset button again. If the motor became overheated it may take it as much as like 20 minutes for the motor to cool enough to allow you to reset.
Be aware that food usually needs to be pushed into the disposer manually, with a full flow of cold water.
Dec 09, 2009 | Dynamic In Sink Erator 41746 HOT-1...
KA KAdette 250 - I hit the switch the other day and nothing happened. I checked the circuit breaker - ok. I also checked the small breaker button on the bottom of the disposal. It is at least 12-years old....
12 years is middle aged for an appliance, but the problem is probably one of the garbage disposal big three: a tripped circuit breaker, a tripped reset button, or a jammed disposer. With the breaker turned off, make sure the disposer's shaft rotates freely. On most disposers there's a hole in the bottom middle where you can insert an allen wrench that you're probably find under the sink and rotate the shaft manually to free jams. But, for the love of God, only do this with the breaker turned off and make sure you remove the wrench (or broom handle if you have to go from the top) from the disposer before turning it on. Make sure the reset is pushed down until it clicks if it's tripped, and, since circuit breakers get old and stick, you'll have to turn the breaker all the way off and back on to make sure it's not tripped. If the disposer hums but doesn't turn when you turn it on, check to see if it's jammed. If it turns freely but hums and doesn't start then the starter circuit on the motor is bad. If the breaker and reset button are ok and it doesn't even hum when you turn it on, you'd want to check the disposer to make sure it's getting power. You can find a little electrical reader at walmart for $5 that works like a geiger counter and will beep when it gets close to something that's receiving power. The switch may be worn out, but really the disposer's motor failing is probably the least likely thing. But please get a qualified electrician out there if you don't know what you're doing. There's a reason that it requires a license.
Oct 25, 2009 | KitchenAid Home
Humming dispoosal
I think I just replied to this thread, and suggested what you seem to have already done. Sorry to say, but the disposal is a gonner. That means the motor has been seized (like a car that runs out of oil). No bringing it back, but easy to replace and not too costly.
Aug 14, 2009 | Badger Basket 1905 Round Doll Bassinet
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
515 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
