I have a Gateway MDP E4100 Motherboard Socket 478 +P4 2.8GHz CPU that is prone to overheating. Where can i get a revised/improved heat sink fo it?
  • DB Corbett
    DB Corbett Oct 08, 2009
    No, that's the original MB with the same heatsink I have... As I clearly said in the request, I am looking for a revised/improved heat sink, not a replacement MB with the same heatsink!
    Dave
  • DB Corbett
    That is much more helpful although your wording makes it difficult to tell if you are saying the 778 or the 475's are better, I think you are recommending the 475's, correct?
  • 10,515 Answers
You can buy it from :-
http://cgi.ebay.com/Gateway-E4100-Motherboard-MPGA478B-With-Heatsink_W0QQitemZ390102160508QQcmdZViewItemQQptZMotherboards?hash=item5ad3e6947c
Any further help, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 08, 2009
  • taran_2005
    taran_2005 Oct 08, 2009
    Thanks for your response!!
    P4 tend to run very hot anyway...it's very important that the HSF is installed properly. There are people who have used 775 as well instead of 478 but, of not much help.
    Here's an assortment of S478 HSF's but they're kinda pricey:
    http://www.svc.com/penivcool.html
    Here's some more:
    http://www.newegg.com/Product/Produ...
    And here's some cheapies:
    http://www.geeks.com/products_sc.as...
    Let me know, if need further assistance.
    Hope i helped you.
  • taran_2005
    As i said above, Original Heat Sink is much better. No doubt you could use a substitute but it would not help very much. What i recommend people would to choose any of the above options like a cooler.
    Thanks.
CPU upgrade for Compaq SR1220NX Desktop Computer
Hi
The specs for this machine state that it is a motherboard with
"Socket 478 for Intel P4 Williamette and Northwood processors
Supports Intel Pentium 4 processor up to 2.8 GHz
Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)"
In other words, any CPU that is not socket 478 ( a fairly old socket now) will not even fit on the board. You do not mention your current CPU so you need to compare it with the spec above to see if you can improve it. It is an old machine/motherboard, so your money might be better going towards a motherboard or system box upgrade.
Cheers
Oct 14, 2014 | Computers & Internet
Can I upgrade e 4100 processor?
Based on the motherboard specifications, and looking at the specs that the Gateway lists for the unit, A Pentium 4 processor socket 478 at 2.8 GHz is the maximum for that machine. Gateway specs show exactly that is what is installed on the E4100. Unfortunately, most pre-built machines have little or no CPU upgradeability since they are built to specs.
Dec 03, 2013 | Gateway Computers & Internet
Need display driver
http://download.cnet.com/mobile-intel-r-945gm/3000-2098_4-98144.html
http://download.cnet.com/intel-r-82852-82855/3000-2098_4-94913.html
if these driver packages are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name display driver you might have to try a few times to get it right
hope this helps
Jun 18, 2012 | Intel E210882 Motherboard Socket Micro Atx...
Gigabite motherboard overheating
Well, you've left a lot to consider. Have you checked that the case and CPU fans are running? Where do the unit sit? Units that are placed inside computer desks that have doors in front of them are just begging for overheating problems as there is very poor air ciculation. Is the CPU sitting on the floor? Here the enemy becomes dust and dirt. Dust and dirt are the most common causes of PC heat issues. The CPU heat sink becomes clogged with dirt and cannot cool effectively. Use canned air (available at most stores that sell PCs) to blow out the heat sinks. DO NOT REMOVE THE HEAT SINK/FAN ASSEMBLY unless you have proper thermal paste to apply for the remounting. Usually a good cleaning is all most machines need.
Jan 03, 2012 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
I am trying to determine what cpu pentel 4 (D) 3.0
Gateway 831GM Pentel 4(D) is for socket 775
Jul 25, 2010 | Gateway 831GM PC Desktop
Fastening Bracket for HP PC m270n PC CPU are broken and cannot fasten heat sink to CPU
Uses Intel processors, that fit in a Socket 478 processor socket. You need a mounting bracket like this, http://www.suntekstore.com/Socket-478-Intel-CPU-Mounting-Bracket.html
You're welcome.
Sometimes those brackets are hard to find
Jan 25, 2010 | HP Media Center PC M270n (DM161A#ABA) PC...
Socket 478 3 GHz Intel CPU overheating
Simply open/unlock the clips and pull the heatsink off. Then you will need to remove the termal compound from both on top of the CPU and from the bottom of the heatsink. Papertowel + rubbing alcohol works well. Then you will need to re-apply thermal compound before reseating the heatsink/fan.
Jun 14, 2009 | Intel Socket 478 CPU COLLING FAN & HEAT...
How to change
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Oct 31, 2008 | Intel Socket 478 CPU COLLING FAN & HEAT...
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
