Question about Sony Cyber-shot DSC-W55 Digital Camera
I have the same problem.
My camera also has a flashing yellow light and says "Access" and the "Turn off power & on again". I've tried everything, but it's still not working. Did you find a solution? If yes, then please email me ASAP at kruti88@hotmail.com
  • 300 Answers
Hi!
It sounds like the lens unit is damaged / stuck. You should contact your local Sony service center. I work in a Sony service center and repair these every day. You can try tapping it as many people do and hope it will fix the problem, but I won't recommend it. It will be expensive at Sony service center, so you can ask a local repair shop about it.
Tom
Posted on Oct 09, 2009
My finepix s3400 will not turn on. I've tried almost everything and I'm really annoyed. Is there something i can do to fix it?
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
Mar 08, 2012 | Fuji FinePix 3800 Digital Camera
I have a Nikon Coolpix L110 and the pictures have a yellow tint when taken inside. I've noticed the yellow tint varies when I point the camera to different areas in the room. I've never had an...
You have a white balance issue. Somewhere in the menu system is a command to alter the white balance - for indoor shooting by artificial light (i.e. light bulbs) it should be set to 'tungsten'. Using flash would overcome this, but the pictures would look very harsh and unnatural.
Jun 14, 2017 | Nikon Coolpix L110 Digital Camera
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Pentax Optio E60 won't turn on
Messed with mine for a while and discovered the following:
I mashed the entire directional pad (ok and arrows) with my big fat thumb and hit power at the same time. This apparently reset something inside the camera and it's now functional again.
Nov 17, 2008 | Pentax Optio E60 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
210 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
