Question about Dacor ECS230 Epicure Electric Double Oven
My oven won't heat after self cleaning. - Dacor ECS230 Epicure Electric Double Oven
  • 1 more comment
  • amy_openshaw Oct 08, 2009
    So you think it is a thermostat problem instead of an element being burned out problem?
    My dacor oven ECS230 wont heat after self cleaning. I have noticed this to be a common problem what should I do?
    Yes, that is what I thought it was. But was wondering if it could be something else. Thanks.
  • 10,865 Answers
Hello this often happens after cleaning. What has occurred is the heating element was on its last legs and that self cleaning reswulting in extreme heat for a long time did it in.
you will have to have a technician come in and replace the heating element.
Posted on Oct 08, 2009
  • 10,515 Answers
On the back of the unit there should be a thermastat.You need to test it for continuity.If it does not have continuity replace it.
You can try to reset the thermocouple as well. It's located on top of the oven, and accessible by removing a panel on the front
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Oct 08, 2009
    Thanks for your response!!
    There might be many other reasons, like Faulty Control board, Bake elements etc.
    I have told you to check thermostat as i have seen issue with thermostat in Dacor Models. I cannot jump to any conclusion.
    To check element :-
    To check them put the oven on broil. If the element on the top starts
    glowing red then it is okay. Then put it on bake and turn the oven to
    350. Check the bottom element to see if it starts turning red. If it
    doesn't then it is bad.
    Let me know, once you done with all the tests.
    Hope i helped you.
Oven won't heat
You may have a blown thermal fuse in series with the heating elements. If the oven exceeded the maximum allowable temperature during self-clean, the fuse will open. See this discussion:
Oven Failure After Self Clean and F1 Errors
Aug 22, 2014 | KitchenAid Ovens
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Oven won't heat up
What is the complete model number of your unit?
Feb 18, 2013 | Kenmore 24" Self-Clean Wall Oven 3055
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not heat up.
If the oven won't heat, did you check both the bake and broil element? If both are not working correctly you are going to have a control board issue most likely. If only one works, then the other should just have to be replaced.
Jul 31, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Aug 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My heating elements are not heating for bake, broil or clean. just finished a round of self cleaning and now oven doesn't heat.
The self clean or self destruct mode has burnt a wire, the relay, or the control...
A tech with an electrical meter will need to check through the wiring and see what burnt up...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Whirlpool RBS275PD Electric Single Oven
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Dacor ECS230 Epicure Electric Double Oven Logo
53 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
