Question about Cameras
I left my Vivitar 285hv on for over 6 hours. I turned it off and when I turned it on the pilot light alternates between red and green and will not fire.
  • 302 Answers
Sounds like something overheated and fried. I suppose you could take it apart to which part looks black.
Prolly needs a new circuit board and/or capacitor. Not sure what the repair cost would be, since it seems Vivitar is no longer in the flash business.
Best bet:
buy another 285HV on Ebay, either broken, for parts, or for replacing your dead one. Keep your old one fer parts.
Posted on Oct 19, 2009
How to remove sensor from Vivitar 285HV Flash
Pull it straight out from the body. See the instructions on page 9 of the manual.
Oct 22, 2012 | Vivitar Used Replacement Vari Sensor...
285, red/green lights blink, whines on start up, but won't fire
Hi Dave,
Try shorting out Center Pin to Outside Metal Contact after the light turned green. This must fire the flash.
If not, could be the flashtube /or trigger are defective.
Do you have a DVM?
atdlee@netzero.com
Feb 14, 2010 | Vivitar 285HV Flash
Replaced batteries, fires once, red light stays on. Turn off, restart, same pattern.
Hi Larry,
Change all four batteries, I think one or more were not 1.25 or more voltages.
atdlee@netzero.com
Jan 11, 2010 | Vivitar 285HV Flash
I can't make the flash work,
Are you serious...you don't know how to turn it on? Ever wonder what the on/off switch is for?
Slide the switch from left to right and wait for the 'ready' light to change from red to green...then it's ready to shoot.
Mar 18, 2009 | Vivitar 285HV Flash
Vivitar 285HV Stop Working
There is nothing wrong with your flash unit. The regular AA batters are 1.5 v volts each- if 4 batteries are used that is a total of 6 volts for proper operation. The rechargeable batteries are 1.2 volts each and 4 will get you 4.8 volts- thats 1.2 volts short and that is probably the root of our problem .
Try recharging you rechargeable batteries and put the im one more time- if the same problem happens you will have to stick with standard AA batteries. There external 6 volt packs that will work with your flash unit0 the are a bit of an expense at first but you will save on replacement batteries in the long run,.
Ed
Nov 27, 2008 | Vivitar 285HV Flash
Will not flash red/green
This means Battery is low to charge the capacitor.
I suggest you test this with unused new Duracell.
Oct 06, 2008 | Vivitar 285HV Flash
So, how high a fall can Vivtar 285HV withstand?
omg, why did it fell? as we know that vivitar flash has so many little components in the inside, since its not really made "crash proof", you might have busted it already.
is the green light only turned on and not blinking?
Jan 21, 2008 | Vivitar 285HV Flash
Will a Vivitar 285HV fry my Canon EOS 40D? I'd like to experiment with a Vivitar 285HV as an on-camera hot shoe flash. However, I'm reluctant to proceed because of conflicting reports about voltage...
Personally, I would not try it. While the Canon has a protection system built into the camera, the trigger voltage on the Vivitar is pretty high. I have had good results using a 283 on a slave shoe, you will have to stop down more with the extra light
Jan 08, 2008 | Vivitar 285HV Flash
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Cameras Logo
189 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
