Question about Bosch 24 in. SHU53 Built-in Dishwasher
Buttons not working
The dishwasher works fine, but I cannot change the cycle because none of the buttons work. It is as though they are all frozen in one position and cannot be depressed to select a different cycle.
Any ideas?
  • tigerlily555 Dec 26, 2007
    Yes, I bought mine used. The owner said it was about seven. Shortly after I installed it, the buttons froze as described. I chose a cycle and wash everything using that cycle. I popped off the button for delay start and use a pencil eraser to set delay start. I would rather use it the way it was designed . . .
  • jimbosmit Feb 16, 2008
    How do you put new buttons in to the control panel.
    President:
  • 1,314 Answers
Contact bosch for technical assistance to se if they have a kit for that maybe a production problem i don't get there svc bulletins
Posted on Dec 30, 2007
Frigidaire dishwasher fdbb2840ec0 cancel button doesn't work
Good Morning Friend,
I understand that the cancel button is not working on your Frigidaire dishwasher, model# FDBB2840EC0. I also see that your appliance will start, but has to fully cycle before stopping, even though the start and cancel button are the same. I suggest resetting your dishwasher, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 22, 2014 | Frigidaire Dishwashers
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
I have a whirlpool Dishwasher and it will not turn on?
keep the start button pressed in - the machine will empty out the water and cancel the cycle....then start over again.
Jan 07, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
Belling integrated dishwasher not working properly
are you sure it is the board at fault, not justv the door catch? (as the door wont open). If the dishwasher believes it has just finished a cycle and the door has not yet been opened it will not let you change the program.
I had this same problem so I hooked an allen key around the back of the white door catch and pulled it into the unlocked position with a pair of pliers. Has worked fine since but every now and then the catch will pop back into the locked position when the door is opened.
Nov 25, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
356 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
