Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Lens will not extend when power turned on. battery is fully charged. beeps 6 times
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
philipp
  • 217 Answers
SOURCE: Canon G5 Lens error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Nov 12, 2007
SOURCE: Camera rapidly beeps 6 times when powered up and immediately turns off!
FIXED!
Just follow Excitebiker above..
Back to nearly normal.. a bit noisy on the gears now.. but working fine.. and it had been dropped
Posted on Jun 29, 2008
SOURCE: My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Posted on Jul 01, 2008
SOURCE: Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Posted on Feb 01, 2009
  • 57 Answers
SOURCE: Canon G10 wont turn on
Try removing the card first and then trying to power up the camera. Cameras often fail to turn on/off when a card goes faulty. Next I would try pushing the playback button, it also acts as a power button but starts the camera in playback mode. If this works it could indicate a problem with the power switch circuit itself. If there is still no sign of life I would suspect a fuse to have blown. They are internally located and very small, you would need to have a service centre try replace it for you. Good Luck!
Posted on Apr 15, 2009
When I turn on my Canon G6 power shot 7.1 megapixels it starts to work and then right when the camera turns on it turns off. I checked the batteries and they were fully charged. After the camera turns
Hi Cayley,
Typically, when an electronic or electro-mechanical device - such as a computer or as in this case - your camera - is powered up; it goes through a "boot up" so to speak. Like your computer, the camera electronics performs some quick, basic checks on the electronic and mechanical systems during the boot up sequence. This often includes checking for the presence of a memory card, battery charge state, connection to a computer via USB cable - and - checking the lens position; and if it can be extended and reversed to a "home" position or not.
Because you're seeing a "lens" message, this is a clue that the camera boot up sequence has detected some sort of problem with the lens. Most often, the problem is tied to the lens not moving or not moving *fully* due to grit or sand lodged between 1) moving parts of the lens or 2) between moving parts of the lens and the stationary parts of the camera body itself. When you turn on the camera, does the lens move in and out - like it did before? If not, that is probably the cause. You can 1) send the camera to be repaired by Canon, 2) have a local repair shop attempt to fix it, 3) replace the camera with new - if it is older than a few years as it may not be worth the cost of investing $$ in old technology - or if this option is your plan, 4) attempt repair yourself. You have nothing to lose - you can try to help the lens extend by pulling while it s"boots" up if it is retracted - or pushing in on it if stuck in an extended position. That is the NORMAL test at boot - to extend then fully retract. You may get it to work, abd save the cost of repair or replacement - or you could damage the mechanism even more.
I hope this helps & good luck!
Mar 24, 2014 | Canon "infrared" Power Shot G6 7.1 Mp...
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
Powers on, lens extends, 3 beeps, lens closes, camera turns off
Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think the camera was getting hung up on the pictures stored in the camera's memory.
Aug 17, 2009 | Cameras
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Battery died while lense extended and now will not power up.
Some of these cameras that have a lens that extends use gears to extend the lens. The gears can strip or get clogged with fine debris and jam the lens. Usung good quality rechargable batteries NOT ALKALINE will usualy have the power to drive the lens.
Ask yourself, how many cycles do you have on the pack? could the pack be weak and not power the camera fully?
Have you tried pushing firmly in on the battery while you power it up? If the camera will not power on with the door open, try and fold a small trip of paper and sit it between the battery and the door. This might push in on the battery enough to better the connection and solve the issue.
If the battery is fine then you may have a lens problem. The lenses can be jammed easy, dropped or an impact when extended is all it takes.
Jan 26, 2009 | Sony Cameras
Lens stuck extended, won't turn back on!
ensure that batterys are properly charged. try formatting the cam from computer
Jan 16, 2009 | Canon PowerShot SD1100 IS Digital Camera
Cannon G7 need help
Hi
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
Beeps 3 times
Is it an actual beep, or is it a beeping noise coming from the lens? Does the lens extend? I ask this because this is the noise the lens focus gears make when they are knocked out of alignment, or debris gets in them and jams them.
Jan 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
