Question about Dell Latitude D610 Notebook
Dell Latitute D610 is no longer working under AC Power
My Dell Latitute D610 is no longer working under AC power. It worked fine under battery power but now the battery is drained and it will not charge. The power LED on the laptop does not light when AC is plugged in.
  • 657 Answers
Please check the AC adapter with another system and confirm if it is working fine. Else get it replaced.
Thank you for using Fixya
Posted on Oct 08, 2009
My dell latitude d610 ac power is work is properly but battrey is not charging plz tell me soulition.
If the D610 works when attached to the AC Power Cord, it is likely that your battery is not capable of taking a charge and needs to be replaced. I have 2 D610 Dell Latitudes and they are very good laptops.
Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Dell Latitude D610 Notebook
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Jan 20, 2011 | Dell Latitude D610 Notebook
My Dell latitude will not re-boot
Did you check your battery LED light or Motherboard?
May be you need a dell latitude d610 battery?
This article can solve your ac adapter problem.
http://www.laptop-junction.com/toast/content/dell-ac-power-adapter-not-recognized
Nov 23, 2010 | Dell Latitude D610 Notebook
D610 Dell Laptop
it seems to be a problem with motherboard as you said you have replaced power supply and ac adaptor , try disconnecting external pheripherals do a flea power it doesnot start then you will have to replace motherboard
Jan 09, 2010 | Dell (F2273) Motherboard
Dell D610 only can run on battery, not accepting AC power or from my docking station. I check the PA-12 AC charger and is working fine with other D610. Please help.
If not powering from DOCK, AC adapter and only from battery, since the Battery, DOck and adapter are known good, it is a matter of a motherboard replacement
Jul 09, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Battery stopped working
Hey,
Test your charger, the battery light blinking and the computer not starting up indicates not enough power to start up or not pluged into ac power, check the power adapter or charger. I suspect the battery is fine.
Thanks,
Ekse
Feb 15, 2009 | Dell Latitude D600 Notebook
My dell lattitude D610 laptop wont charge battery
before you come to that conclusion, try it on AC power only
get back to us if the problem is still the same
regards
Dec 22, 2008 | Dell Latitude D600 Notebook
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Dell D610 Batteries don't charge when AC adater is plugged
this is usually a sign of a common problem with these laptops. Usually the power works but it will not power the batteries to charge them. If the power adapter is fine- you have a bad motherboard.
Nov 23, 2007 | Dell Latitude D600 Notebook
Dell Latitude D610 Notebook Logo
238 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
