Question about Acer TravelMate 4202WLMi Notebook
Can't tell what my DVD drive is capable of
Do I really need an external DVD burner for my Acer 4202 laptop? I've burned CDs and played DVDs on it before, but when I try to burn a DVD+R disc it says the disc is either full or flawed. Tried multiple new discs. "My Computer" shows this as the drive: HL-DT-ST DVDRAM GSA-4082N -- but my owner's-manual specs refer to "Storage subsystem" optical drive options of 8X DVD-Super Multi double-layer and 8X DVD-Dual double-layer. What's the "8X" for if not a burn speed? And the drive door has an emblem that says "DVD multi recorder"
Could this be a driver problem, or is my drive less than advertised?
KurtM
    President:
  • 1,187 Answers
The DVD drive is an 8X burner, not a ROM (read-only).
The laser lens may need cleaning.
Radio Shack has a CD/DVD laser lens cleaner ($13). It is an audio CD with a row of brushes. No chemicals involved. Read and follow directions.
It won't mess anything if not done correctly.
Best DVD media is Verbatim. Best price is found at OfficeMAX.
Posted on Oct 08, 2009
I have just bought a toshiba satellite c650d. Will it play DVD's. It is running on Windows 7 and has 4GB of ram
Toshiba Satellite C650D has a DVD Drive and it is capable of playing DVDs.Certainly, it will play DVD. It even supports High Defination (HD) video. So, ENJOY!
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Feb 03, 2011 | Computers & Internet
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
DVDs play with no audio
Nothing went wrong but it require audio codecs to be installed your DVD drive must be having a CD with it which has nero burning softwares and other like nero show time and dvd codecs. Install this programe from the cd supplied with it. use power DVD etc. many softwares are there .dvd play back
Aug 10, 2009 | Acer Aspire One PC Notebook
My dvd drive will not play original dvds or + dvds but will play dvds and cds burn on - dvds and cds
Hello there:
you might need to check to see the format of the dvd that you are trying to play ie dvdr vice dvd some devices will not play them if the format of the cd is wrong
Aug 06, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
Dvd burner plays dvd's and cd's fine, will burn cd's but will not burn dvd's
Unless you have one of the very latest laptops, your model laptop most likely has a DVD ROM combo drive - which allows you to play DVDs and CDs also burn CDs/
You need to give me the make and model number of your laptop for me to verify if your laptop is capable of burn DVDs.
Jun 21, 2009 | HP Computers & Internet
Dvd/cd-rw combo does not record
You may have what is called a combo drive...it can play and burn cds but can only play dvds, not burn them. Look at the face plate on the drive and see what is written on it. If it has the following:
Recordable Drive = CD Burner
DVD = DVD Player
RW & DVD = DVD Burner
If recordable drive and DVD is on the drive but no RW, chances are its a combo drive. Keep us posted.
Feb 24, 2009 | Acer ASPIRE 3680-2022 Notebook
Help with my cd player/burner
There could be several things which are causing your CD burner not to act in the way it should.
I had a similar type problem after installing Windows XP, .Service Pack 3 onto my Sony VAIO model VGN-SZ330P.
The standard Windows burner kept saying there was no CD in the drive but it would play both CDs and DVDs.
I went looking for an alternative and now use IMGBURN which is a free lightweight CD / DVD / HD DVD / Blu-ray burning application . You can find it at http://www.imgburn.com/.
I also installed CDBurnerXP which is another free application to burn CDs and DVDs, including Blu-Ray and HD-DVDs. It also includes the feature to burn and create ISOs, as well as a multilanguage interface. You can find it at http://cdburnerxp.se/en/home
The above does not tell you why your burner is having problems (and they could be numerous), it will certainly get the burner doing everything you need.
Oct 16, 2008 | Sony VAIO VGN-FS980 Notebook
My dvd burner doesn't burn dvds
You need to check that with blank DVD's you are using compatible with your drive.Because the DVD's may work with your extranal drive but not with your builting drive. If this doen't slove the problem I would recommend using a different burning software other than "sonic record now" and "vista o/s Built-in dvd burner".
Sep 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Burn DVD
Read on your optical drive. If it burns CD's it reads CD-RW. In order to burn DVD's it needs ro read DVD-RW. If it reads DVD-ROM it will only read DVD's not burn them.
A good external burner is Plextor. You can get one at Walmart, or you can check Ebay and find an internal to replace the one in your machine. They are fairly easy to replace, and you won't have a bulky external to carry around.
Jun 09, 2008 | Dell Inspiron B130 Notebook
Dvd rom
not necessrilly some dvd rom drives play only dvds an cds but don't burn them. it may burn cds but there is a 90% chance your drive can't burn dvd's
Nov 17, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Acer TravelMate 4202WLMi Notebook Logo
219 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
