Amp i got hold of a technics sh-av500 procesor to run with my existing amp but i am not sure how to connect it! could you please help\; Regards Bob
  • 682 Answers
Take audio right and left out from your processor and connect it to aux in or line in in your amplifier.
Posted on Apr 24, 2008
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
Aug 22, 2011 | Technics SH-GE70 Home Equalizer
I have got the technics SH-EH550 UNIT, but i want to utilise the suround sound functions of the SH-EH750 unit on my system. is it just a case of unplug the EH550 unit and replace that with the EH750 unit...
As you stated technics SH-EH550 UNIT can be replaced with SH-EH750 unit ,
Since this unit has the main power Amplifier with suround sound functions in it,you do not need the other units unless you do not plan to use..
Hope this helps!..if more help requires pls let me know.
Jul 07, 2011 | Audio Players & Recorders
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
I have the following system Technics SL-D202,
Since all of your connectors are filled, I suggest you this solution:
Use either of this or this connector (2 connectors, each for every channel) and connect 2 of the input devices (that you don't use at the same time, like cd and tuner) at the same input of the amplifier. Move the line out of the tape deck at the line input that just get free. Don't connect the line in of the tape deck. Use the amplifier connector's for tape to connect the equaliser in - out.
This solution has the disadvantages:
not able to rec to tape (I assume that you don't use this function anymore),
you have to power of one of the devices that are connected together at the same input while the other one is active
And these advantages:
You can use your existing equipment for your proposes without paying more than 0.16$
You can make a quick changeover between equalized and flat audio using the tape monitor switch.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. In case you'd like ask me to create a connection diagram for your case.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 08, 2011 | Technics Audio Players & Recorders
Dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
Nov 09, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
95 people viewed this question
 Grubhead
Grubhead
