Question about Compaq Presario 5000 PC Desktop
When I turn on my laptop a box pops up saying engine file does not exist. How do I resolve this?
  • Jaye Ellen Burke
    Jaye Ellen Burke May 11, 2010
    More info needed: WHAT engine file does not exist? Maybe something was installed one time that's gone now?
  • rmccarthy24 May 11, 2010
    whats type of laptop, what OS are u using (vista, Linux), do you have the cds that came with the laptop, is there a repair option that you can use.
    Novelist:
  • 102 Answers
Download and install Java Virtual Machine (Software) and this will Fix the problem
Posted on Oct 09, 2009
Advent 4211
The Boot Manager file may be corrupted or as it says missing. You must reinstall the operating system. Use the hidden recovery partition if it (still) exists or the recovery media that shipped with the computer. If no recovery media came with the computer, you must contact the Vendor and order them. You will in all likelihood have to pay for them.
Nov 03, 2013 | Computers & Internet
Will turn in but won't really start up, message pops up sayin I have problems on my laptop but it can't fix them? Read description
When your toshiba splash screen is showing on startup, press F8 continuously, then you should get some options, go to the one that says safe mode. After loading windows in safe mode click start, search, and type system restore. Open system restore, find a date where your pc was working correctly and click restore. If this doesn't do it on the toshiba spash screen (if you have a new enough laptop) there will be an option called system recovery usually f11 key, this will restore your pc back to its factory state and should resolve any problems your having. If you don't have that option go to https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp and see if you can order a set of recovery disc's for your model, they usually run from $25-$30. Hope this helps.
Mar 01, 2012 | Toshiba Computers & Internet
Received a Blue Screen with Fatal Error
Please turn on the machine and keep hitting softly the F8 button on the keyboard.
When the list of options show up, select SAFE MODE and wait for the PC to load default drivers. Once asked to log in, please select "ADMIN". If none exists then select your user account.
A pop-up greets you, just click on "OK" to proceed.
Click on "Start"
Click on "My Computer"
Right click on your hard-drive and select "Properties"
Click on "Tools" tab
In the dialog box, check both options that is
"Automatically fix file system errors"
and
"Scan for and attempt recovery of bad sectors"
Click "Start" and accept by clicking on "YES" to accept a scheduled scan.
Nov 30, 2010 | Computers & Internet
Cannot find map data files
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 06, 2010 | Computers & Internet
When i push to navigate it says the file does not exist
You will probably need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  5. A menu pops up.
  12. Click "Start"
Good luck.
Mar 30, 2009 | Nextar X4-T Car GPS Receiver
Wmf graphics filter missing! what is a wmf graphic filter?
To resolve this issue, rename the Wmfimp32.flt file:
  1. Click Start, point to Find, and then click Files or Folders.
  2. In the Named field, type wmfimp32.flt.
  3. In the Look in box, click Local hard drives, and then click to select the Include Subfolders check box.
  4. Click Find Now.
  5. Right-click the Wmfimp32.flt file, and then click Rename.
  6. Type wmfimp32.old.
  7. Press ENTER.
  8. Close the Find: Files Named Wmfimp32.old dialog box.
  9. Reinstall the program.
Dec 31, 2008 | Computers & Internet
Message pop-up says hp library not updated
It should only update
usually will ask for your confirmation and it will tell you if your files would be over written
Nov 28, 2008 | Acer Aspire 5100-5022 Notebook
Installation problem
What i suspected is true now...I'm 100% sure the disk you are trying to install is not Compatible for Windows Vista.I will provide you the link and you can download and install the printer.Before you download i need you to do following steps that i recommend.
1.Disconnect the printer form PC.
2.Click start - control panel - programs and features.Check if you have any printer software, if u see them, uninstall it.if NO, dont worry.
3.Restart the PC.
4.Download the file by clicking in the link below.
Click here to download the Printer software for Vista
DOWNLOAD
Note: After clicking on Download wait for few seconds you will get a small pop up box to download the software.After Downloading install it, Problem will be resolved.I'm 100 % sure.Contact me if u need any further assistance.
Thanks
Riz
(jack_36623@gmail.com)
Apr 21, 2008 | HP Photosmart 2575 All-In-One InkJet...
Hidden Song Files on an ILO
The songs are in the wrong format
Jan 11, 2008 | iLO (2 GB) MP3 Player
Compaq Presario 5000 PC Desktop Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
