Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Front loader Controls Locked
At the end of a wash, the timer went to 1 minute for 30 minutes. It seemed it was going through the rinse cycle. I hit the cancel button. Now the "Controls Locked" light is on and I can not get the washer to start.
  • Anonymous Mar 23, 2008
    Kenmore HE3 Ouiet Pak 2 has the control light on that says control locked.
    What to do?
  • Anonymous Jun 12, 2008
    The cycle stopped and than a light came on next to "control locked." I've tried pressing various buttons and then unplugged the machine for an hour or so. No luck.
    President:
  • 1,294 Answers
Try 'end of cycle' pushed down till the light goes off. Or locate the button with diagram of 'lock', & push down till the light goes off.
Posted on Mar 16, 2008
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Ran HE3 without Water, it's now locked up
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
138 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
