Question about Dell Vostro 1510 Laptop
Function key is required to type with keyboard
    Brigadier General:
  • 3,513 Answers
Hi
There are F key for toggleing and locking in the Numeric keypad that doubles as your alpha numeric board needs to be released. This is usually a combination of keys which share a similar color.
4 Using the keypads
The computer has an embedded numeric keypad and also supports an optional external numeric keypad
or an optional external keyboard that includes a numeric keypad.
Component Description
(1) fn key Executes frequently used system functions when pressed in
combination with a function key or the esc key.
(2) Embedded numeric keypad Can be used like the keys on an external numeric keypad.
(3) num lk key Enables the embedded numeric keypad when pressed in
combination with the fn key.
8 Chapter 4 Using the keypads
Using the embedded numeric keypad
The 15 keys of the embedded numeric keypad can be used like the keys on an external keypad. When
the embedded numeric keypad is turned on, each key on the keypad performs the function indicated by
the icon in the upper-right corner of the key.
Enabling and disabling the embedded numeric keypad
Press fn+num lk to enable the embedded numeric keypad. Press fn+num lk again to return the keys to
their standard keyboard functions.
NOTE: The embedded numeric keypad will not function while an external keyboard or numeric keypad
is connected to the computer.
Switching key functions on the embedded numeric keypad
You can temporarily alternate the functions of keys on the embedded numeric keypad between their
standard keyboard functions and their keypad functions by using the fn key or the fn+shift key
combination.
● To change the function of a keypad key to keypad functions while the keypad is off, press and hold
the fn key while pressing the keypad key.
● To use the keypad keys temporarily as standard keys while the keypad is on:
◦ Press and hold the fn key to type in lowercase.
◦ Press and hold fn+shift to type in uppercase.
Using an optional external numeric keypad
Keys on most external numeric keypads function differently according to whether num lock is on or off.
(Num lock is turned off at the factory.) For example:
● When num lock is on, most keypad keys type numbers.
● When num lock is off, most keypad keys function like the arrow, page up, or page down keys.
To turn num lock on or off on an external keypad as you work:
▲ Press the num lk key on the external keypad, not on the computer.
Thanks for contacting Fixya.com
Posted on Oct 08, 2009
4 Suggested Answers
  • 749 Answers
SOURCE: Function keyboard turned on advent QT5500
Hi
Try this my friend,
Press F12, Num Lock, and FN at the same time.
OR F12 and Num Lock/ Scroll Key.
OR Hold the Ctrl and Fn key down together and press also
the Ins(Num LK) key.
Post me whatever the result is... so we could Fixya the problem.
Posted on Feb 03, 2008
TheLaptopGuy
  • 12 Answers
SOURCE: keyboard probs advent 9115 laptop
Sounds like your num lock has been toggled on by mistake. Look for a key that says NmLK. It will be in the same color blue. That key may also be the scroll lock key(ScrLk) that should solve your problem.
Thanks
Todd
www.LaptopGuy.com
Posted on Apr 23, 2008
leecom72
  • 4806 Answers
SOURCE: I own an HP 510 laptop, when i type the function
You have the Num Lock on.
To turn it off just hit the Num Lock key or press Fn and hit the Num Lock key to return the keyboard to normal.
Regards.
Posted on Jun 28, 2010
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Function key doesnt work
The laptop keyboard will need to be replaced, go to www.ebay.com Type: make and model of laptop, refine search to keyboard.
May 21, 2012 | Sony VAIO SZ Series Notebook VGN-SZ780EB
Keyboard works except the upper symbols when I am typing in Outlook. How can I resolve this?
The upper symbols on the keyboard are called function keys usually not expected to respond when pressed. functions keysy are ysed to control the computers settings either when malfcuntions occur or computer requires alternations to another feature possibility. Every available keys are displayeable besides fucntions keys on user productivity programs.
Feb 03, 2011 | Logitech 967437-0403 Keyboard
I own an HP 510 laptop, when i type the function symbol on the right side of the keyboard is displayed for eg if I want an L 3 is typed, O is 6 etc. To eliminate this I must press the FN key to get the...
Regards.
Jun 28, 2010 | HP 510 Notebook
0y 2eyb6ard n6t w6r25ng
Replace the keyboard ? It appears that the Function key (Fn) is "stuck" on. Depressing the Fn key (for keys with a Fn function) will "correct" the typing. How do you reset the Function key ?
Dec 07, 2009 | Computers & Internet
Multimedia keyboard on function keys. Functions work with a key "Function" How to change "Multimedia keys first" on "Function keys first" ???
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Nov 01, 2009 | Dell Inspiron 1545 Notebook
Locked keyboard buttons
You need to find the special function key that, when used with the Fn key, locks the Fn function on. On my keyboard it's the F11 key.
Press the Fn key and that key and your keyboard will return to normal.
Apr 20, 2009 | HP DC170B Keyboard
I need help in understanding the keyboard functions
dear,
what does it mean. do you want to know the hotkeys of just want to speed up your typing speed.
if you mean is to speed up you typing speed. then use softwares like typing tutor etc. i used typing tutor 6. it is an old version but is simple too. now i can type very fastly.
or if you want hotkeys then visit this links:
http://users.sa.chariot.net.au/~kday/keyboardtips.html
http://www.helpwithpcs.com/tipsandtricks/keyboard_shortcuts_microsoft_word.htm
http://wiki.blender.org/index.php/Manual/Hotkeys/Hotkey_Keyboard_Map,
the last one is impressive.
regards,
salman
Jul 22, 2008 | Computers & Internet
Keyboard stuck in upper case
press caps lock and F9 together see if that fixes it
May 06, 2008 | Microsoft Windows XP Home Edition
Dell Vostro 1510 Laptop Logo
565 people viewed this question
Alun Cox
